09-16-2015 03:45 AM - edited 03-08-2019 01:48 AM
I have bought 10 brand new WS-C4510R+E. SUP 8E-10GE and 8 x 4748 blades per chassis.
At first it ran without a problem, then the ports stop giving out power for the phones.
I have enough power to support them.
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 1015 2200
Inline Power (-50V) 498 4800
Backplane Power (3.3V) 40 40
Total 1553 (not to exceed Total Maximum Available = 6000)
Interface Admin Oper Power(Watts) Device Class
From PS To Device
Gi1/25 auto off 0.0 0.0 n/a n/a
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Gi1/25 60.0 15.4
The Ethernet data part still works 100% if you connect a computer directly. Just the power for the phone disappear. Tried different class Cisco phones. I deleted the configuration on the port, made it a switch port again, shut/no shut. You call it, I've done it. Directly connect the phone to the switch nothing works. If you remove a active phone working 100% on the same blade and reconnect it back, it also can't start up again. At some stage the port tells you it gives power out, but there is no power coming out of the blade on the phone directly connected to the switch blade. All 3 installed switches started doing it on different blades.
Reload the blade and all is fine for about 1 months, then it starts randomly gain. Once reloaded, you can plug and unplug as you want, all is fine then.
3 switches, same problem, same solution. How can we fix this?
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e
s8-UNIVERSALK9NPE-M), Version 03.06.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 27-Jun-14 06:38 by prod_rel_team
ROM: 15.1(1r)SG5
xxxxxxx uptime is 16 weeks, 2 hours, 53 minutes
Uptime for this control processor is 16 weeks, 2 hours, 55 minutes
System restarted at 09:46:00 zat Wed May 27 2015
Running default software
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
Last reload reason: power-on
Johan
Solved! Go to Solution.
09-16-2015 03:55 AM
Version 03.06.00.E
Just to be sure, upgrade to the "gold release" 3.6.3E.
09-16-2015 03:55 AM
Version 03.06.00.E
09-16-2015 04:00 AM
I will do and give you feedback.
Johan
09-21-2015 05:17 AM
I have an almost identical issue. The only differences are that I'm using WS-X45-SUP7-E, and IOS 03.04.01. However, the condition of the fault is exactly the same.
James
09-21-2015 05:48 AM
James
You won't believe. I installed the new software, the bootvar points to the new software, but it doesn't boot from the new image. I then deleted the old image and it was ready to run the new software. When I put the old image back on the bootflash and it reloaded it went back to the old one. So I deleted it again and now I'm on the new version. Will keep you updated.
Johan
11-04-2015 11:04 PM
James
Just to update. Switches still running without any problems. Software did make a difference.
Johan
11-04-2015 11:05 PM
Leo
Loaded the software and it is still running fine.
Johan
