05-23-2011 05:38 AM - edited 03-06-2019 05:12 PM
I have cisco 6509 with IOS (12.2(18)SXF17a) and I want to install the WS-X6748-GE-TX. I will install it in Slot 7.
Please let me know if there is any power require for the installation of extra module. Currently I have two power supply installed.
Below is current status of power supply
CORE02#show power
system power redundancy mode = redundant
system power total = 2771.16 Watts (65.98 Amps @ 42V)
system power used = 1365.84 Watts (32.52 Amps @ 42V)
system power available = 1405.32 Watts (33.46 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 2771.16 65.98 OK OK on
2 WS-CAC-3000W 2771.16 65.98 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 WS-C6509-E-FAN 150.36 3.58 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-X6748-SFP 254.94 6.07 254.94 6.07 on on
2 WS-X6548-GE-TX 125.16 2.98 125.16 2.98 on on
4 WS-X6548-GE-TX 125.16 2.98 125.16 2.98 on on
5 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
6 (Redundant Sup) - - 282.24 6.72 - -
9 WS-SVC-NAM-2 145.74 3.47 145.74 3.47 on on
Below is the show version and module status mention.
CORE02#show module version
Mod Port Model Serial # Versions
1 48 WS-X6748-SFP SAL1130VVHB Hw : 1.10
Fw : 12.2(14r)S5
Sw : 12.2(18)SXF17a
Sw1: 8.6(0.306)R3V42
WS-F6700-CFC SAL1131W0Z1 Hw : 3.1
2 48 WS-X6548-GE-TX SAL1131W32Y Hw : 11.3
Fw : 7.2(1)
Sw : 8.5(0.46)RFW58
4 48 WS-X6548-GE-TX SAD0806073J Hw : 7.0
Fw : 7.2(1)
Sw : 8.5(0.46)RFW58
5 2 WS-SUP720-3B SAL1130VSN3 Hw : 5.4
Fw : 8.4(2)
Sw : 12.2(18)SXF17a
WS-SUP720 SAL1130VQY4 Hw : 3.0
Fw : 12.2(17r)S4
Sw : 12.2(18)SXF17a
WS-F6K-PFC3B SAL1130VH3H Hw : 2.3
9 8 WS-SVC-NAM-2 SAD09290909 Hw : 3.0
Fw : 7.2(1)
Sw : 3.4(1a)
ENOCDC_CORE02#show module prov
ENOCDC_CORE02#show module provision
Module Provision
1 dynamic
2 dynamic
3 dynamic
4 dynamic
5 dynamic
6 dynamic
7 dynamic
8 dynamic
9 dynamic
CORE02#show version
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF17a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by cisco Systems, Inc.
Compiled Tue 02-Mar-10 02:55 by tinhuang
Image text-base: 0x40101040, data-base: 0x42DD9E90
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF17a, RELEASE SOFTWARE (fc1)
ENOCDC_CORE02 uptime is 31 weeks, 2 days, 20 hours, 45 minutes
Time since ENOCDC_CORE02 switched to active is 31 weeks, 2 days, 20 hours, 44 minutes
System returned to ROM by power cycle (SP by power on)
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF17a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of memory.
Processor board ID SMC11280087
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
51 Virtual Ethernet/IEEE 802.3 interfaces
154 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Your input and suggestion will be highly appreciated.
Solved! Go to Solution.
05-23-2011 06:13 AM
The WS-X6748-GE-TX requires 325W to run. According to your output, you have more than enough power to install it (1405.32 Watts). Ensure that your IOS is up to snuff, 12.2(17a)SX or later, which you appear to be on top of; for running the module, and you should be fine.
Please rate if helpful.
Message was edited by: Antonio Knox
05-23-2011 06:13 AM
