WS-X6748-GE-TX question...
petersmiddy
Trying to calculate how many end-users would be able to pull down data at 100Mbs each from a Server that has a 1Gb connection to a WS-X6748-GE-TX card, presuming worst-case scenario in which every user would be maxing out their respective 100MB connection, bearing in mind that the server’s 1GB connection resides on a ws-x6748-ge-tx card that has a 2x20GB switch fabric connection on the backplane to the SUP720 supervisor module.
SERVER-->SWITCH1(1GB port on ws-x6748-ge-tx)-->(2 x 1GB Uplink)SWITCH2-->(2 x 1GB Uplink)SWITCH3-->END USERS w/ 100Mb connections
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Unclear what you're really asking, since you describe switch2 and switch3, but don't describe them. You also don't describe what else is connected to the 6748 line card ports, how busy those other ports might be, what else is in the chassis, whether the 6748 has a DFC, how busy other ports in the other line cards might be, how busy the other switches and their uplinks might be, etc.
In theory, the GigEtherent connection should be able to max out 10 FastEthernet connections.
