WS-X6816-10GE over-subscription ? line rate ? please help !
Shlomy Maron
I didn't understand the documentation - what is the throughput of WS-X6816-10GE with CFC sub module ?
what would I gain if I buy DFC sub module ?
what is the effect of the Port-Grouping ? what are the Port-Grouping ?
I have the following Issue - ports 22 to 30 are in use , while most of them are in 50-70% usage of bandwidth.
one of them complained about packet loss when receiving multicast stream.
the way I've solved it was to move his port to 40, while 30-48 are empty.
I've tested it several times with the same cable - and it is the right solution.
(the multicast stream is incoming from another line card)
so I must ask - isn't WS-X6816-10GE line rate module ?
please help with some explanation
2 Accepted Solutions
Hello Shlomy,
These cards are 4:1 oversubscribed by default.
If you want to use them at line rate you need to use that in Performance mode (disabling 3 ports in a port group and using only 1)
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/data_sheet_c78-451794.html
Madhu
One more useful link
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/qa_c67-362061.html
Hello Shlomy,
Madhu
