X2-10GB-CX4 for VSS
Ibrahim Jamil
Level 6
Level 6
Hi Experts
Does the below Supports the VSL Link using 6500 VSS?
  • X2-10GB-CX4=
  • CAB-INF-26G-15=
thanks
5 Replies 5
rsimoni
those are an optic module and a cable... they are not relavant for vss.
what you need to check is the line card(s) the vsl link resides on.
okay can we use it to connect both 6500 to form a VSS Switch???????
if the linecard used for vsl is supported yes you can... but your question does not make too much sense...
i will use the 2 x 10GE Available on the sup of the 6500
if the optic is supported on those sup ports it will be supported for vss too.
