X2-10GB-SR compatible with 3750-E?
Marlon Malinao
i will be buying 2 x 3750-E and will connect our server with 10G to the x2 port of 3750.  is X2-10gb-SR compatible with this? do i need any converter module?
thanks,
marlon
Here is the compatibility matrix of CISCOs 10G tranceivers : http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
As you can see X2-10GB-SR is compatible with the 3750E switch.
