XENPAK-10GB-LR with Cisco 6509-no signal
ariyer2003
Hi Experts
I have cisco 6509 with the following modules.The issue i am facing is that the LR optics are not lighting up.As per the software advisor i tried the following software images.The SR modules within the same chassis works.The issue is there with my other switches like cisco 4900M,Cisco 3750-E all of which have the LR modules and they dont lit up whereas the SR does.Kindly help me out.
rgds
ashwin
s72033-ipservicesk9-wan-mz.12.2.-33.SXI3
s72033-ipservicesk9-wan-mz.12.2.-33.SXh6
s72033-ipservicesk9-wan-mz.12.2.-33.SXf16
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  4    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  6    2  Supervisor Engine 720 (Cold)           WS-SUP720-3B
  1  Centralized Forwarding Card WS-F6700-CFC       SAL13516UNL  4.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL13516K6T  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL13516US2  4.1    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL13516MGM  4.1    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1350604W  2.6    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL135067FL  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       SAL135068FE  2.6    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL1350639R  4.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
17 Replies 17
Jerry Ye
What type of fiber is in between? XENPAK-10GB-LR only works on single mode fiber (SMF). While SR is only requres multi-mode fiber (MMF).
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5455_Products_Data_Sheet.html
HTH,
jerry
I am aware that LR works with single mode.The question is shoudnt i be seeing some red laser inside the optic as soon as it is inserted into the line card??
rgds
ashwin
I suggest you not to look at it. This is a powerful laser and it can damage your eye. Also, the wave length is very small (1310nm), you might not able to see if if you decide to look at it. The best way to do it is to use an optical power meter to check if there is any power coming out from the XENPAK.
jerry
Are you sure it is not visible to the naked eye as compared to SR.Kindly confirm this.I also recieved that this LR works only with 12.2(33)SRA
According to the table:
http://docstore.mik.ua/univercd/cc/td/doc/product/core/cis7600/hardware/7600_hw2.htm#wp1307300
12.2(33)SRA is the only one that is supported.
rgds
ashwin
doesnt look like your IOS is support for this transceiver!!!
Table 6 Catalyst 6XXX Switch Support and Minimum Software Release Requirements
Platform
Switch or Module
Transceiver Model
Minimum Software Release Required
Catalyst Operating System
Cisco IOS
DOM Support
Catalyst 6500 series
WS-X6704-10GE
WS-SUP32-10GE-3B
XENPAK-10GB-LR
XENPAK-10GB-LR+
XENPAK-10GB-LW
XENPAK-10GB-ER
XENPAK-10GB-ER+
XENPAK-10GB-LX4
XENPAK-10GB-SR
XENPAK-10GB-CX4
XENPAK-10GB-ZR
XENPAK-10GB-LRM
DWDM XENPAK
8.1(2)
8.1(2)
8.4(4)
8.2(1)
8.2(1)
8.2(1)
8.3(1)
8.3(1)
8.5(1)
8.6
8.5(1)
12.2(17a)SX
12.2(17a)SX
12.2(18)SXE
12.2(17a)SX
12.2(17a)SX
12.2(17a)SX1
12.2(17a)SX1
12.2(17a)SXB1
12.2(18)SXF
12.2(18)SXF11
12.2(18)SXF
12.2(18)SXE
12.2(18)SXE
12.2(18)SXE
12.2(18)SXF
12.2(18)SXF11
12.2(18)SXF
you have a newer code and i dont think the table is up-to-date!!!
Francisco.
The table said Minimum Software Release Required. Any IOS above that in the same train, SX, will support that module.
i am unable to find this ios.can you help?? this is what is available in cisco
rgds
ashwin
Your IOS
s72033-ipservicesk9-wan-mz.12.2.-33.SXH6
s72033-ipservicesk9-wan-mz.12.2.-33.SXF16
are fine.
but still same issue
What is the issue? The remote end, XENPAK-10GB-LR (or any 10G-LR) with SMF, is not detecting the link or you are still trying to look at the light?
Hi Jeye,
the issue is the 6509  XENPAK-10GB-LR - link is not coming up while connecting to 4900 cisco XENPAK-10GB-LR in which is located in one of the HUB-Rooms
Just for a quick L1 test, you can use a single strand SMF and connect the same XENPAK TX and RX together to check if it is working or not. The good XENPAK should give you a green light if you look at the front when connecting the TX and RX together.
I would follow Jerry's advice and not try to look at the light.
Jerry, does the loopback test you proposed require the use of an attenuator? I think I see that in the asterisks of Table 1 in the document included in your first post.
