GigabitEthernet1/0/35 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is bc4a.56b6.9ba3 (bia
bc4a.56b6.9ba3)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 3d19h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 17
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 59000 bits/sec, 38 packets/sec
67950 packets input, 16515793 bytes, 0 no buffer
Received 27509 broadcasts (27089 multicasts)
0 watchdog, 27089 multicast, 259 pause input
2637909 packets output, 482996489 bytes, 0 underruns
Output 1310054 broadcasts (0 multicasts)
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit GigabitEthernet1/0/35 Receive
92435140759 Total bytes 3393932497 Total bytes
51084128 Unicast frames 17836424 Unicast frames
59464585684 Unicast bytes 2490139957 Unicast bytes
135567068 Multicast frames 2599344 Multicast frames
24590294734 Multicast bytes 898623362 Multicast bytes
121827847 Broadcast frames 59521 Broadcast frames
8369462261 Broadcast bytes 5169178 Broadcast bytes
1 System FCS error frames 0 IpgViolation frames
0 MacUnderrun frames 0 MacOverrun frames
0 Pause frames 24824 Pause frames
0 Cos 0 Pause frames 0 Cos 0 Pause frames
0 Cos 1 Pause frames 0 Cos 1 Pause frames
0 Cos 2 Pause frames 0 Cos 2 Pause frames
0 Cos 3 Pause frames 0 Cos 3 Pause frames
0 Cos 4 Pause frames 0 Cos 4 Pause frames
0 Cos 5 Pause frames 0 Cos 5 Pause frames
0 Cos 6 Pause frames 0 Cos 6 Pause frames
0 Cos 7 Pause frames 0 Cos 7 Pause frames
0 Oam frames 0 OamProcessed frames
0 Oam frames 0 OamDropped frames
126428160 Minimum size frames 14750458 Minimum size frames
106046015 65 to 127 byte frames 1575468 65 to 127 byte frames
12259633 128 to 255 byte frames 1835734 128 to 255 byte frames
3235843 256 to 511 byte frames 803271 256 to 511 byte frames
23505647 512 to 1023 byte frames 770285 512 to 1023 byte
frames
37003746 1024 to 1518 byte frames 784898 1024 to 1518 byte
frames
0 1519 to 2047 byte frames 0 1519 to 2047 byte
frames
0 2048 to 4095 byte frames 0 2048 to 4095 byte
frames
0 4096 to 8191 byte frames 0 4096 to 8191 byte
frames
0 8192 to 16383 byte frames 0 8192 to 16383 byte
frames
0 16384 to 32767 byte frame 0 16384 to 32767 byte
frame
0 > 32768 byte frames 0 > 32768 byte frames
1 Late collision frames 1 SymbolErr frames
1451 Excess Defer frames 171301 Collision fragments
811539 Good (1 coll) frames 1105870 ValidUnderSize frames
202091 Good (>1 coll) frames 0 InvalidOverSize frames
18269 Deferred frames 0 ValidOverSize frames
0 Gold frames dropped 0 FcsErr frames
0 Gold frames truncated
1 Gold frames successful
811539 1 collision frames
151280 2 collision frames
41832 3 collision frames
7654 4 collision frames
1150 5 collision frames
143 6 collision frames
25 7 collision frames
7 8 collision frames
0 9 collision frames
0 10 collision frames
0 11 collision frames
0 12 collision frames
0 13 collision frames
0 14 collision frames
0 15 collision frames
0 Excess collision frames
