Xmit-Err
D@1984
I've got 4 interfaces bundled between my switches. when I check the show int counter error, xmir-err is too high on those interfaces on one side. I've checked all interfaces on both sides and they are all configured full duplex, 100mb/s, I also have no buffer errors on the individual interfaces when I run show interface.
As I understand xmir-err is likely due to speed mismatch but the port-channel wouldn't be up if there was a speed mismatch( I have gigabit on one side and Fa on the other side though).
Is it something that I should be worried about? I have some devices on  the switch with fa ports that stop working randomly, and I have to disconnect, reconnect them again to get them working (not sure if this is related to the errors), also some users connecting to that switch complain about performance and that they get better speed on wireless than LAN.
24 Replies 24
what is the code of SW you use?
WS-C3850-24P and WS-C3750-48TS
Let me share what I know about this issue may be it help you
there is buffer for each interface
ingress and egress buffer,
this buffer divide according to QoS, where each class take some space in this buffer.
NOW
what this lead to
using port channel need some kind of balance which is hash, and hash depend on source and destination.
what if all source and destination hash lead to one specific interface of port channel ?
Now the problem become worse when this interface have small buffer size for specific Class of traffic.
this make buffer full  and tail drop and low performance.
when you do any change remember to clear counter to see the effect of change.
there is no qos config on the switch, and from below commands, I could only run the middle one.
Can you share output here
show platform software status control-processor brief<- check memory utilize
show process memory sorted<-check which process eat your SW memory
show memory allocating-process totals<- check if the Process above not free memory after forward traffic.
If you can share the output for above.
sw1#show process memory sorted
System memory : 3930980K total, 1548968K used, 2382012K free, 221420K kernel reserved
Lowest(b) : 1788387652
PID Text Data Stack Heap RSS Total Process
10440 91272 37788 108 288 239664 391632 iosd
5863 10316 243332 92 47924 202656 545848 fed
10436 25664 536064 88 7548 114420 679184 wcm
6340 4 109184 116 103528 110764 129780 idope.py
5865 784 102464 88 1184 52672 233712 stack-mgr
6425 124 92320 88 6464 46292 134952 cli_agent
6410 5072 88640 100 5500 45108 233964 ffm
11326 4 82736 236 17228 44924 150692 wnweb_paster.py
6411 1576 231832 88 14244 42940 284140 eicored
5864 676 90964 92 984 35172 185864 platform_mgr
6402 52 51108 88 296 22880 116552 pdsd
6427 888 160052 88 5352 21796 205236 snmp_subagent
6419 28 17164 88 164 21148 76732 liin_tap
6408 44 21268 88 164 21088 80984 mgmte_tap
6404 1032 42348 88 2556 12044 81912 osinfo-provider
6395 1144 103176 88 1812 10904 148328 obfld
10437 168 76868 88 1196 10148 119544 table_mgr
6409 320 125536 88 628 9536 166908 installer
10441 252 51748 88 620 9040 91868 ha_mgr
6400 44 47808 88 584 8532 86408 plogd
6407 60 32124 88 296 7648 75668 mem_mgmt
6403 164 22568 88 296 7168 63948 gold_slave
5598 1440 11044 88 808 7076 44656 system_mgr
6412 268 42504 88 768 6748 76488 dtmgr
10439 52 38984 88 464 6504 74556 iifd
6399 52 52056 88 296 6476 88996 system_mgr_cli
6401 88 34728 88 296 6020 131960 psdprov
6413 212 37868 88 164 5960 78192 cpumemd
6398 44 34740 88 296 5872 69756 csprovider
6405 180 34720 88 296 5808 68472 oscore_p
6436 36 33696 88 296 5796 67212 sysinfo_p
6429 116 33696 88 296 5724 67296 erm_p
6433 80 34784 88 296 5712 68352 ngdumper_provid
6393 84 34716 88 292 5660 68280 profiled
6396 40 33696 88 296 5616 67196 consoled
5821 132 43624 88 944 5400 60648 slproc
6397 16 13544 88 320 5036 41512 console_relay
6406 28 22368 88 164 4688 50928 netd
11327 20 1000 88 132 4072 25648 xlogger
6392 20 13184 88 296 3716 39908 ns_oir_proxy
8959 20 824 88 132 3332 20996 xlogger
8295 20 824 88 132 3324 20996 xlogger
8213 768 1964 88 1916 3224 5084 rollback_timer.
4950 12 764 88 132 3028 18952 epc_sm_liaison
11393 48 836 88 132 2576 14116 in.telnetd
6460 8 8952 88 164 2516 21748 fs_cmd
8293 768 1952 88 1904 2428 5072 rollback_timer.
6394 768 1004 88 956 2284 4124 oom_poll.sh
8705 768 480 88 432 1752 3600 nova_sntp.sh
1 324 368 88 264 1740 4708 init
10438 768 368 88 320 1624 3488 wnweb.sh
3466 384 180 88 132 1380 3356 dbus-daemon
11394 768 132 88 84 1364 3252 bexec.sh
11398 768 104 88 56 1336 3224 vty_attach.sh
11397 768 92 88 44 1276 3212 mcp_chvrf.sh
4947 768 108 88 60 1256 3228 sh
3846 24 880 88 784 1152 2616 klogd
3976 24 880 88 784 1152 2616 lockd
3926 220 360 88 132 1072 6316 sshd
3978 220 360 88 132 1072 6316 nfsd
8958 768 480 88 432 956 3600 nova_sntp.sh
4390 768 440 88 392 944 3560 sh
3938 144 320 88 132 812 3328 xinetd
3942 144 320 88 132 812 3328 xinetd
3979 144 320 88 132 796 3328 nfsd
3980 144 320 88 132 796 3328 nfsd
2483 120 300 88 264 756 2392 udevd
3990 84 260 88 132 756 2808 rpc.mountd
1003 120 364 88 264 752 2456 udevd
2484 120 300 88 264 740 2392 udevd
8963 60 160 88 132 724 3336 sntp
8298 20 244 88 132 588 2072 inotifywait
4393 20 244 88 132 524 2072 inotifywait
5887 28 160 88 132 472 1900 sleep
3858 16 160 88 132 464 1888 portmap
3977 16 160 88 132 460 1888 nfsd
2 0 0 0 0 0 0 kthreadd
3 0 0 0 0 0 0 migration/0
4 0 0 0 0 0 0 sirq-high/0
5 0 0 0 0 0 0 sirq-timer/0
6 0 0 0 0 0 0 sirq-net-tx/0
7 0 0 0 0 0 0 sirq-net-rx/0
8 0 0 0 0 0 0 sirq-block/0
9 0 0 0 0 0 0 sirq-block-iopo
10 0 0 0 0 0 0 sirq-tasklet/0
11 0 0 0 0 0 0 sirq-sched/0
12 0 0 0 0 0 0 sirq-hrtimer/0
13 0 0 0 0 0 0 sirq-rcu/0
14 0 0 0 0 0 0 desched/0
15 0 0 0 0 0 0 migration/1
16 0 0 0 0 0 0 sirq-high/1
17 0 0 0 0 0 0 sirq-timer/1
18 0 0 0 0 0 0 sirq-net-tx/1
19 0 0 0 0 0 0 sirq-net-rx/1
20 0 0 0 0 0 0 sirq-block/1
21 0 0 0 0 0 0 sirq-block-iopo
22 0 0 0 0 0 0 sirq-tasklet/1
23 0 0 0 0 0 0 sirq-sched/1
24 0 0 0 0 0 0 sirq-hrtimer/1
25 0 0 0 0 0 0 sirq-rcu/1
26 0 0 0 0 0 0 desched/1
27 0 0 0 0 0 0 migration/2
28 0 0 0 0 0 0 sirq-high/2
29 0 0 0 0 0 0 sirq-timer/2
30 0 0 0 0 0 0 sirq-net-tx/2
31 0 0 0 0 0 0 sirq-net-rx/2
32 0 0 0 0 0 0 sirq-block/2
33 0 0 0 0 0 0 sirq-block-iopo
34 0 0 0 0 0 0 sirq-tasklet/2
35 0 0 0 0 0 0 sirq-sched/2
36 0 0 0 0 0 0 sirq-hrtimer/2
37 0 0 0 0 0 0 sirq-rcu/2
38 0 0 0 0 0 0 desched/2
39 0 0 0 0 0 0 migration/3
40 0 0 0 0 0 0 sirq-high/3
41 0 0 0 0 0 0 sirq-timer/3
42 0 0 0 0 0 0 sirq-net-tx/3
43 0 0 0 0 0 0 sirq-net-rx/3
44 0 0 0 0 0 0 sirq-block/3
45 0 0 0 0 0 0 sirq-block-iopo
46 0 0 0 0 0 0 sirq-tasklet/3
47 0 0 0 0 0 0 sirq-sched/3
48 0 0 0 0 0 0 sirq-hrtimer/3
49 0 0 0 0 0 0 sirq-rcu/3
50 0 0 0 0 0 0 desched/3
51 0 0 0 0 0 0 events/0
52 0 0 0 0 0 0 events/1
53 0 0 0 0 0 0 events/2
54 0 0 0 0 0 0 events/3
55 0 0 0 0 0 0 cpuset
56 0 0 0 0 0 0 khelper
59 0 0 0 0 0 0 netns
60 0 0 0 0 0 0 async/mgr
165 0 0 0 0 0 0 sync_supers
167 0 0 0 0 0 0 bdi-default
169 0 0 0 0 0 0 kblockd/0
170 0 0 0 0 0 0 kblockd/1
171 0 0 0 0 0 0 kblockd/2
172 0 0 0 0 0 0 kblockd/3
178 0 0 0 0 0 0 ata/0
179 0 0 0 0 0 0 ata/1
180 0 0 0 0 0 0 ata/2
181 0 0 0 0 0 0 ata/3
182 0 0 0 0 0 0 ata_aux
191 0 0 0 0 0 0 khubd
221 0 0 0 0 0 0 rpciod/0
222 0 0 0 0 0 0 rpciod/1
223 0 0 0 0 0 0 rpciod/2
224 0 0 0 0 0 0 rpciod/3
258 0 0 0 0 0 0 kswapd0
259 0 0 0 0 0 0 aio/0
260 0 0 0 0 0 0 aio/1
261 0 0 0 0 0 0 aio/2
262 0 0 0 0 0 0 aio/3
263 0 0 0 0 0 0 nfsiod
265 0 0 0 0 0 0 crypto/0
266 0 0 0 0 0 0 crypto/1
267 0 0 0 0 0 0 crypto/2
268 0 0 0 0 0 0 crypto/3
814 0 0 0 0 0 0 scsi_eh_0
823 0 0 0 0 0 0 mtdblockd
898 0 0 0 0 0 0 kstriped
900 0 0 0 0 0 0 ksnapd
903 0 0 0 0 0 0 edac-poller
938 0 0 0 0 0 0 octeon-ethernet
1394 0 0 0 0 0 0 flush-8:0
1677 0 0 0 0 0 0 loop1
1695 0 0 0 0 0 0 loop2
1713 0 0 0 0 0 0 loop3
1731 0 0 0 0 0 0 loop4
1749 0 0 0 0 0 0 loop5
1834 0 0 0 0 0 0 loop6
3981 0 0 0 0 0 0 nfsd
3982 0 0 0 0 0 0 nfsd
3983 0 0 0 0 0 0 nfsd
3984 0 0 0 0 0 0 nfsd
#show processes memory sorted
Processor Pool Total: 91444656 Used: 27278048 Free: 64166608
I/O Pool Total: 12574720 Used: 8478540 Free: 4096180
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 42494996 10350028 29932628 0 0 *Init*
50 0 1256100 136580 954340 10776 0 Stack Mgr Notifi
0 0 4209708804 4150093404 784580 13804532 684872 *Dead*
240 0 42976316 42451984 531240 0 0 hulc running con
132 0 434472 22344 414316 0 0 HL2MCM
131 0 421596 9376 414316 0 0 HL2MCM
81 0 127476156 100735268 161984 0 0 hpm main process
122 0 2405826684 1418676296 94076 4070952 0 HQM Stack Proces
13 0 112480 102016 90116 0 16380 Entity MIB API
236 0 65844 520 67220 2268 0 RADIUS
123 0 2451012184 2451004444 60908 5076 0 HRPC qos request
95 0 4744 5948 60908 0 0 HACL Acl Manager
117 0 0 0 60908 0 0 HL3U PBR bkgrd p
86 0 1269574776 1262949696 55956 4339980 0 HRPC pm-counters
232 0 462895540 2220075688 49132 24024708 0 SNMP ENGINE
64 0 324615776 324468760 40540 71064 0 HRPC hlfm reques
69 0 1123470128 1091126112 35288 21197376 0 HRPC hulc misc r
164 0 1798562968 1215145004 31924 360396 0 CDP Protocol
205 0 4412 0 29320 0 0 LICENSE AGENT
8 0 0 0 24908 0 0 Crash writer
203 0 81353240 74842240 23800 0 0 DHCPD Receive
34 0 1851188012 31616 23712 81216 0 Per-Second Jobs
1 0 90629752 90614916 23288 0 0 Chunk Manager
218 1 28244 18312 23068 0 0 Virtual Exec
83 0 16131480 16076432 22348 0 0 HRPC pm request
217 0 103604 72376 21952 3120 0 VLAN Manager
20 0 41516 12920 21372 0 0 IPC Seat Manager
51 0 10196 180 16924 0 0 Fifo Error Detec
216 0 12286824 32199832 16412 0 0 PM Callback
5 0 9252748 92708860 15556 7774228 60233248 Pool Manager
169 0 2443512 8580364 14320 11340 0 IP Input
230 0 1199230152 1197198192 13956 1314684 0 IP SNMP
0 0 13728 96985256 13728 0 0 *Sched*
30 0 349764 208804 13316 0 0 Net Background
181 0 7380 180 13144 0 0 MDFS LC Process
134 0 396 180 13124 0 0 CEF switching ba
173 0 396 180 13124 0 0 CEF background p
39 0 396 180 13124 0 0 Collection proce
185 0 584 31116 13064 0 0 TCP Timer
32 0 5228 180 13024 2268 0 Logger
31 0 364 364 12908 0 0 IDB Work
26 0 0 0 12908 0 0 License IPC serv
25 0 0 0 12908 0 0 License IPC stat
186 0 72389344 16068 12908 0 0 TCP Protocols
12 0 0 0 12908 0 0 Policy Manager
28 0 180 180 12908 0 0 XML Proxy Client
49 0 0 0 12908 0 0 Stack Mgr
159 0 180 180 12908 0 0 MDFS MFIB Proces
234 0 1152 1048 12908 0 0 SNMP Traps
89 0 0 0 12908 0 0 HCEF ADJ Refresh
239 0 7916 3176 12908 0 0 hulc cfg mgr mas
233 0 0 0 12908 0 0 SNMP ConfCopyPro
115 0 25080116 0 12908 0 0 HL3U bkgrd proce
60 0 0 0 12908 0 0 HIPC bkgrd proce
68 0 0 0 12908 0 0 HRPC hrcmd reque
71 0 0 0 12908 0 0 HVLAN main bkgrd
231 0 1462959040 452 12908 0 0 PDU DISPATCHER
109 0 5424 380 11952 0 0 HRPC hudld reque
188 0 4176 2308 11776 0 0 HTTP CORE
210 0 4824 688 11552 0 0 VTP Trap Process
196 0 11227588 13214376 10980 0 0 MLDSN L2MCM
190 0 11194260 13316944 10480 0 0 IGMPSN L2MCM
126 0 17288 5664 10244 0 0 HRPC system post
200 0 216 0 10124 0 0 IP RIB Update
155 0 180 180 9908 0 0 Switch IP Host T
133 0 212 212 9908 0 0 EAPoUDP Process
174 0 0 0 9908 0 0 IP IRDP
220 0 0 0 9908 0 0 Licensing MIB pr
195 0 2888 180 9616 0 0 L2TRACE SERVER
135 0 1385651456 180 9488 50760 0 PI MATM Aging Pr
136 0 2184 0 9092 0 0 Switch Backup In
176 0 3008 960 8956 0 0 XDR mcast
208 0 2048 180 8776 0 0 TPLUS
225 0 1816 348 8488 0 0 OBFL Cfg Dispatc
107 0 8836 1880 8312 0 0 HRPC stp_state_s
144 0 828 180 7556 0 0 DTP Protocol
238 0 29980 26052 7408 0 0 NTP
184 0 668 180 7396 0 0 Cluster Base
102 0 512 180 7240 0 0 Hulc Foxhound Pr
152 0 472 180 7200 0 0 UDLD
129 0 276 0 7184 0 0 DHCPD Database
153 0 216 0 7124 0 0 Port-Security
171 0 1234568 1032 7124 0 0 Spanning Tree
3 0 7819912 5490952 7112 0 0 SpanTree Helper
9 0 412 229676 7088 0 0 ARP Input
154 0 0 0 6964 0 0 MDFS LC Download
77 0 74608928 20229224 6960 10152 0 HCMP sync proces
211 0 180 180 6952 0 0 VTPMIB EDIT BUFF
229 0 0 0 6932 0 0 SNMP Timers
87 0 3772 1900 6908 0 0 hpm vp events ca
88 0 0 0 6908 0 0 HRPC hcmp reques
85 0 406216504 3642344656 6908 167508 0 hpm counter proc
90 0 0 0 6908 0 0 HRPC hl3mm reque
82 0 38243760 32670640 6908 5076 0 HPM Stack Sync P
92 0 5607360 5607360 6908 0 0 hl3mm
93 0 0 0 6908 0 0 HACL Queue Proce
94 0 0 0 6908 0 0 HRPC acl request
80 0 0 0 6908 0 0 DHCPD Timer
96 0 0 0 6908 0 0 HRPC backup inte
97 0 358324 1155060 6908 0 0 SpanTree Flush
98 0 0 0 6908 0 0 HRPC cdp request
99 0 1386360 700400 6908 5076 0 HRPC dot1x reque
100 0 28516864 17616436 6908 5076 0 HULC DOT1X Proce
101 0 0 0 6908 0 0 HRPC foxhound re
79 0 0 0 6908 0 0 HPM Msg Retry Pr
103 0 0 0 6908 0 0 HRPC sdm request
104 0 180 180 6908 0 0 Hulc Storm Contr
105 0 180 180 6908 0 0 HSTP Sync Proces
106 0 0 0 6908 0 0 HRPC stp_cli req
78 0 1792 1792 6908 0 0 HRPC ilp request
108 0 180 180 6908 0 0 S/W Bridge Proce
76 0 608 332 6908 0 0 HRPC hfbm reques
110 0 0 0 6908 0 0 HRPC vqpc reques
111 0 0 0 6908 0 0 HRPC iec_load_ba
112 0 0 0 6908 0 0 HRPC l2pt qnq rp
113 0 0 0 6908 0 0 HRPC hled reques
75 0 0 0 6908 0 0 HULC VLAN REF Ba
74 0 40104184 39910512 6908 126900 0 HRPC vlan reques
116 0 546120736 546035516 6908 55836 0 HRPC hl3u reques
73 0 240 240 6908 0 0 Vlan shutdown Pr
118 0 0 0 6908 0 0 HL3U PBR n-h res
72 0 180 180 6908 0 0 HVLAN Mapped Vla
120 0 0 0 6908 0 0 HRPC show_forwar
121 0 0 0 6908 0 0 HRPC snmp reques
67 0 180 180 6908 0 0 HLFM address ret
66 0 180 180 6908 0 0 HLFM aging proce
124 0 0 0 6908 0 0 HRPC span reques
125 0 0 0 6908 0 0 HRPC obfl reques
65 0 301087404 180 6908 15228 0 HLFM address lea
127 0 4344 2448 6908 0 0 Hulc Reload Mana
128 0 1664 1664 6908 0 0 HRPC hrcli-event
63 0 9241080 9241080 6908 0 0 HRPC hpsecure re
130 0 180 180 6908 0 0 image mgr
62 0 5285480 1884228 6908 0 0 Hulc Port-Securi
61 0 0 0 6908 0 0 RTTYS Process
59 0 352 352 6908 0 0 HRPC hdm blockin
58 0 4832 4556 6908 0 0 HRPC hdm non blo
57 0 732 180 6908 0 0 HULC Device Mana
56 0 68 68 6908 0 0 HRPC hcomp reque
137 0 0 0 6908 0 0 MMN bkgrd proces
138 0 180 180 6908 0 0 Dot1x Mgr Proces
139 0 0 0 6908 0 0 MAB Framework
140 0 0 635156 6908 0 0 802.1x switch
141 0 180 180 6908 0 0 802.1x MDA Aging
142 0 0 0 6908 0 0 802.1x Webauth F
143 0 0 0 6908 0 0 802.1x Critical
55 0 287705172 2179876632 6908 10152 1011816 hrpc <- response
145 0 0 0 6908 0 0 EAP Framework
146 0 0 0 6908 0 0 HRPC dai request
54 0 0 0 6908 0 0 hrpc -> request
148 0 0 0 6908 0 0 HRPC dhcp snoopi
149 0 1248 708 6908 0 0 HULC DHCP Snoopi
150 0 0 0 6908 0 0 HRPC ip source g
151 0 0 0 6908 0 0 HULC IP Source g
53 0 0 11472080 6908 0 7522632 hrpc -> response
47 0 180 180 6908 0 0 MIRAGE RBCP Moni
46 0 11556 9244 6908 0 0 HULC multifs pro
45 0 0 0 6908 0 0 HRPC Multi-FS Sy
156 0 0 0 6908 0 0 Link State Group
157 0 180 180 6908 0 0 Ethchnl
158 0 3400780 1278800 6908 0 0 VMATM Callback
44 0 180 180 6908 0 0 HLPIP Sync Proce
160 0 0 0 6908 0 0 IPv6 RIB Redistr
161 0 180 180 6908 0 0 AAA Server
162 0 0 0 6908 0 0 AAA ACCT Proc
163 0 0 0 6908 0 0 ACCT Periodic Pr
43 0 0 0 6908 0 0 HRPC lpip reques
165 0 0 0 6908 0 0 DiagCard2/-1
166 0 5451192 5443452 6908 5076 0 HRPC hl2mcm igmp
167 0 204 204 6908 0 0 AAA Dictionary R
168 0 0 236 6908 0 0 DHCP Snooping
42 0 0 0 6908 0 0 HRPC emac reques
170 0 0 0 6908 0 0 ICMP event handl
41 0 0 0 6908 0 0 HRPC hdwl reques
172 0 473705468 247607648 6908 35532 0 Spanning Tree St
40 0 180 180 6908 0 0 DownWhenLooped
38 0 180 180 6908 0 0 Compute load avg
175 0 0 0 6908 0 0 CEF RF HULC Conv
37 0 0 0 6908 0 0 Net Input
177 0 7244 0 6908 0 0 IPC LC Message H
178 0 0 0 6908 0 0 XDR RP Ping Back
179 0 12676028 12676028 6908 0 0 XDR RP backgroun
180 0 0 0 6908 0 0 XDR RP Test Back
36 0 0 0 6908 0 0 AggMgr Process
182 0 180 180 6908 0 0 Cluster L2
183 0 0 0 6908 0 0 Cluster RARP
35 0 0 0 6908 0 0 Per-minute Jobs
33 0 180 1508 6908 0 0 TTY Background
29 0 0 0 6908 0 0 Critical Bkgnd
187 0 0 0 6908 0 0 Socket Timers
27 0 180 180 6908 0 0 GraphIt
189 0 0 0 6908 0 0 RARP Input
24 0 0 0 6908 0 0 ARP Snoop
191 0 0 0 6908 0 0 IGMPSN MRD
192 0 0 0 6908 0 0 IGMPSN
193 0 0 0 6908 0 0 IGMPQR
194 0 0 0 6908 0 0 CEF MQC IPC Back
23 0 0 0 6908 0 0 Dynamic ARP Insp
22 0 0 0 6908 0 0 HC Counter Timer
197 0 0 0 6908 0 0 MRD
198 0 0 0 6908 0 0 MLD_SNOOP
199 0 9544 1804 6908 5076 0 HRPC hl2mcm mlds
21 0 0 0 6908 0 0 IPC Session Serv
201 0 0 0 6908 0 0 Auth-proxy AAA B
202 0 0 0 6908 0 0 IP Admin SM Proc
19 0 0 0 6908 0 0 IPC Deferred Por
18 0 0 0 6908 0 0 IPC Managed Time
206 0 180 180 6908 0 0 AAA Cached Serve
207 0 180 180 6908 0 0 LOCAL AAA
17 0 0 0 6908 0 0 IPC Periodic Tim
209 0 0 0 6908 0 0 HRPC x_setup req
16 0 0 0 6908 0 0 IPC Zone Manager
15 0 0 0 6908 0 0 IPC Dynamic Cach
212 0 180 180 6908 0 0 DHCP Security He
213 0 0 0 6908 0 0 HCD Process
214 0 0 0 6908 0 0 HRPC cable diagn
215 0 124 400 6908 0 0 DiagCard1/-1
14 0 0 0 6908 0 0 IFS Agent Manage
11 0 204 204 6908 0 0 AAA high-capacit
10 0 0 152 6908 0 0 AAA_SERVER_DEADT
219 0 180 180 6908 0 0 dhcp snooping sw
7 0 0 0 6908 0 0 HRPC asic-stats
221 0 216 216 6908 0 0 RADIUS TEST CMD
222 0 180 180 6908 0 0 AAA SEND STOP EV
223 0 0 0 6908 0 0 Syslog Traps
224 0 0 0 6908 0 0 SAA MPLSLM Proce
6 0 180 180 6908 0 0 Timers
4 0 0 0 6908 0 0 Check heaps
114 0 180 180 6908 0 0 Hulc LED Process
119 0 0 0 6908 0 0 HRPC dtp request
227 0 180 180 3908 0 0 CSRT RAPID TRANS
226 0 180 180 3908 0 0 STP FAST TRANSIT
147 0 0 0 3908 0 0 HULC DAI Process
91 0 0 0 3908 0 0 hl3md_rpfq_thrl_
84 0 3892 3340 3908 0 0 HPM if_num mappi
70 0 136 136 3908 0 0 HRPC system mtu
52 0 576 576 3908 0 0 Adjust Regions
48 0 0 0 3908 0 0 HRPC hsm request
2 0 180 180 3908 0 0 Load Meter
35745308 Total
Finally check cpu utilize is process
iosd and fed is high or not ?
3850# show process cpu sorted
Core 0: CPU utilization for five seconds: 8%; one minute: 9%; five minutes: 10%
Core 1: CPU utilization for five seconds: 1%; one minute: 3%; five minutes: 4%
Core 2: CPU utilization for five seconds: 1%; one minute: 2%; five minutes: 4%
Core 3: CPU utilization for five seconds: 5%; one minute: 6%; five minutes: 6%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
10440 4012958 21229703 136 1.64 1.90 2.05 34816 iosd
5863 3415123 24679070 35 0.85 0.95 0.99 1088 fed
3750#show process cpu sorted
CPU utilization for five seconds: 5%/0%; one minute: 5%; five minutes: 5%
123 26140745 12787141 2044 0.31% 0.15% 0.15% 0 HRPC qos request
9 39702956 104070325 381 0.15% 0.15% 0.17% 0 ARP Input
3 441 4925 89 0.00% 0.00% 0.00% 0 SpanTree Helper
4 14203660 1894610 7496 0.00% 0.08% 0.06% 0 Check heaps
2 106 3197303 0 0.00% 0.00% 0.00% 0 Load Meter
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 1 0 0.00% 0.00% 0.00% 0 HRPC asic-stats
5 2952 3408 866 0.00% 0.00% 0.00% 0 Pool Manager
1 3921 62055 63 0.00% 0.00% 0.00% 0 Chunk Manager
10 0 7 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
11 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit
12 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
Speed Mismatch !!!
where the speed mismatch is it in ether channel between two SW ? NO
the Speed mismatch is between the Port/Interface
when the packet arrive from Server which connect to 1G and must send to other SW, the buffer of interface of Etherchannel is full because it use 100 M not 1G.
I Know we have two or three or more port in ether channel but hence the speed still same, when the hash will be select one port to send traffic it will used it Speed which is 100 M.
so solution as friends suggest is
increase the SoftMax to be 1200 time bigger than it.
if this solution not solve issue then friend we must consider change the speed.
normally the speed is low in access and it increase in connect between access and aggregate SW.
I hope this help you.
