xmodem keeps failing
mrSS
Hello there...
I got a 3560 8 port and trying to transfer the IOS via xmodem. It failed twice.  I formatted the fsck the flash but still no luck.  Anybody know any other work arounds to this?
switch: flash_init
Initializing Flash...
mifs[3]: Invalid fd sctr=2
mifs[3]: Error writing sector 1 error 3    <===
mifs[3]: Root directory corrupted!
mifs[3]: Failed to do fsck
...done Initializing Flash.
Thanks in advance..
Reza Sharifi
Most likely you have a bad flash card.  If it is under warranty or you have a service contract with Cisco, RMA it.
Reza
i was suspecting that as well...its def not under warranty..its my personal 3560...do you or anybody knows how to replace the flash?
If I remember correctly, the flash in not removable.  It is soldered on the mother board. Can you open it up and take a look inside?
