12-04-2015 07:31 AM - edited 03-08-2019 02:57 AM
Please help me to interpret these commands from Xtreme platform for a Cisco WS-C3750X-24T-E ..
THANK YOU
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.09.21 15:38:31 =~=~=~=~=~=~=~=~=~=~=~=
telnet session telnet0 on /dev/ptyb0
login: admin
password:
ExtremeXOS
Copyright (C) 2000-2008 Extreme Networks. All rights reserved.
Protected by US Patent Nos: 6,678,248; 6,104,700; 6,766,482; 6,618,388; 6,034,957; 6,859,438; 6,912,592; 6,954,436; 6,977,891; 6,980,550; 6,981,174; 7,003,705; 7,017,082; 7,046,665; 7,126,923; 7,142,509; 7,149,217; 7,152,124; 7,154,861.
Press the <tab> or '?' key at any time for completions.
Remember to save your configuration changes.
X350-24t.1 # sh vlan X350-24t.1 # sh vlan
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
DAF 1063 ------------------------------------- ANY 2 /2 VR-Default
Default 100 ------------------------------------- ANY 2 /2 VR-Default
dse 1033 ------------------------------------- ANY 2 /2 VR-Default
GCEF 1081 ------------------------------------- ANY 2 /2 VR-Default
grn 1064 ------------------------------------- ANY 17/19 VR-Default
gtf 1035 ------------------------------------- ANY 5 /6 VR-Default
lgra 1046 ------------------------------------- ANY 2 /2 VR-Default
Mgmt 4095 ------------------------------------- ANY 0 /1 VR-Mgmt
mng 120 10.0.0.43 /24 ----------------- ANY 2 /2 VR-Default
USOC 1009 ------------------------------------- ANY 2 /2 VR-Default
voz 210 ------------------------------------- ANY 21/26 VR-Default
Flags : (C) EAPS Control vlan, (d) NetLogin Dynamically created VLAN,
(D) VLAN Admin Disabled, (E) ESRP Enabled, (f) IP Forwarding Enabled,
(i) ISIS Enabled, (L) Loopback Enabled, (l) MPLS Enabled,
(m) IPmc Forwarding Enabled, (n) IP Multinetting Enabled,
(N) Network LogIn vlan, (o) OSPF Enabled, (p) PIM Enabled,
(P) EAPS protected vlan, (r) RIP Enabled,
(T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled
Total number of Vlan(s) : 11
X350-24t.2 # sh conf X350-24t.2 # sh configuration
# Module devmgr configuration.
configure snmp sysName "X350-24t"
configure snmp sysContact "support@extremenetworks.com, +1 888 257 3000"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vman ethertype 0x88a8
create vlan "DAF"
configure vlan DAF tag 1063
configure vlan Default tag 100
create vlan "dse"
configure vlan dse tag 1033
create vlan "GCEF"
configure vlan GCEF tag 1081
create vlan "grn"
configure vlan grn tag 1064
create vlan "gtf"
configure vlan gtf tag 1035
create vlan "lgra"
Press <SPACE> to continue or <Q> to quit:configure vlan lgra tag 1046
create vlan "mng"
configure vlan mng tag 120
create vlan "USOC"
configure vlan USOC tag 1009
create vlan "voz"
configure vlan voz tag 210
configure ports 25 auto off speed 10000 duplex full
configure ports 26 auto off speed 10000 duplex full
configure vlan DAF add ports 24 tagged
configure vlan DAF add ports 4 untagged
configure vlan Default add ports 23-24 tagged
configure vlan dse add ports 23-24 tagged
configure vlan GCEF add ports 23-24 tagged
configure vlan grn add ports 24 tagged
configure vlan grn add ports 2, 7-23 untagged
configure vlan gtf add ports 23-24 tagged
configure vlan gtf add ports 1, 3, 5-6 untagged
configure vlan lgra add ports 23-24 tagged
configure vlan mng add ports 23-24 tagged
configure vlan USOC add ports 23-24 tagged
configure vlan voz add ports 1-26 tagged
configure vlan mng ipaddress 10.0.0.43 255.255.255.0
Press <SPACE> to continue or <Q> to quit:configure qosscheduler strict-priority
# Module fdb configuration.
configure fdb agingtime 300
configure iparp vr VR-Default max_entries 4096
configure iparp vr VR-Default max_pending_entries 256
configure iparp vr VR-Default max_proxy_entries 256
configure iparp vr VR-Default timeout 20
enable iparp vr VR-Default checking
enable iparp vr VR-Default refresh
configure iparp vr VR-Mgmt max_entries 4096
configure iparp vr VR-Mgmt max_pending_entries 256
configure iparp vr VR-Mgmt max_proxy_entries 256
configure iparp vr VR-Mgmt timeout 20
enable iparp vr VR-Mgmt checking
enable iparp vr VR-Mgmt refresh
configure neighbor-discovery cache vr VR-Default timeout 10
configure neighbor-discovery cache vr VR-Mgmt timeout 10
# Module rtmgr configuration.
Press <SPACE> to continue or <Q> to quit:#
disable iproute sharing
configure iproute priority mpls 20
configure iproute priority blackhole 50
configure iproute priority static 1100
configure iproute priority icmp 1200
configure iproute priority ebgp 1700
configure iproute priority ibgp 1900
configure iproute priority ospf-intra 2200
configure iproute priority ospf-inter 2300
configure iproute priority rip 2400
configure iproute priority ospf-as-external 3100
configure iproute priority ospf-extern1 3200
configure iproute priority ospf-extern2 3300
configure iproute priority bootp 5000
configure iproute ipv6 priority blackhole 50
configure iproute ipv6 priority static 1100
configure iproute ipv6 priority icmp 1200
configure iproute ipv6 priority ospfv3-intra 2200
configure iproute ipv6 priority ospfv3-inter 2300
configure iproute ipv6 priority ripng 2400
configure iproute ipv6 priority ospfv3-as-external 3100
configure iproute ipv6 priority ospfv3-extern1 3200
Press <SPACE> to continue or <Q> to quit:configure iproute ipv6 priority ospfv3-extern2 3300
configure irdp broadcast
configure irdp 450 600 1800 0
disable irdp "mng"
disable icmp address-mask vlan "mng"
enable icmp parameter-problem vlan "mng"
enable icmp port-unreachables vlan "mng"
enable icmp unreachables vlan "mng"
enable icmp redirects vlan "mng"
enable icmp time-exceeded vlan "mng"
disable icmp timestamp vlan "mng"
enable ip-option loose-source-route
enable ip-option strict-source-route
enable ip-option record-timestamp
enable ip-option router-alert
enable ip-option record-route
configure iproute add default 10.0.0.1 1 vr VR-Default
disable ipforwarding broadcast vlan "mng"
disable icmp useredirects
configure ipforwarding originated-packets dont-require-ipforwarding
# Module mcmgr configuration.
configure igmp snooping cache 32 64
configure igmp snooping timer 260 260 vr VR-Default
configure igmp snooping leave-timeout 1000 vr VR-Default
configure MLD snooping timer 260 260 vr VR-Default
configure MLD snooping leave-timeout 1000 vr VR-Default
disable igmp snooping forward-mcrouter-only vr VR-Default
disable MLD snooping forward-mcrouter-only vr VR-Default
configure igmp 125 10 1 2 vr VR-Default
configure MLD 125 10 1 2 vr VR-Default
enable igmp snooping with-proxy vr VR-Default
enable MLD snooping with-proxy vr VR-Default
configure igmp snooping flood-list none vr VR-Default
configure MLD snooping flood-list none vr VR-Default
disable mvr vr VR-Default
# Module aaa configuration.
disable radius mgmt-access
configure radius mgmt-access timeout 3
disable radius-accounting mgmt-access
configure radius-accounting mgmt-access timeout 3
Press <SPACE> to continue or <Q> to quit:disable radius netlogin
configure radius netlogin timeout 3
disable radius-accounting netlogin
configure radius-accounting netlogin timeout 3
disable tacacs
configure tacacs timeout 3
disable tacacs-accounting
configure tacacs-accounting timeout 3
disable tacacs-authorization
configure account admin encrypted D4TvSY$MTHabcda8Yl7vH7UBPUPw/
configure account user encrypted ruTvSY$MCfqZMH21l1sovfFTPOTW1
create account admin Wsanchez encrypted D4Tgob$TuPNtSlKClhcnGNaZF72i0
# Module acl configuration.
enable access-list refresh blackhole
configure access-list zone DOS zone-priority 1
configure access-list zone SYSTEM zone-priority 2
configure access-list zone SECURITY zone-priority 3
configure access-list zone DOS application Dos application-priority 1
configure access-list zone SYSTEM application Cli application-priority 1
configure access-list zone SYSTEM application IpSecurity application-priority 2
Press <SPACE> to continue or <Q> to quit:configure access-list zone SYSTEM application NetLogin application-priority 3
configure access-list zone SECURITY application GenericXml application-priority 2
# Module cfgmgr configuration.
disable cli-config-logging
configure cli max-sessions 8
configure cli max-failed-logins 3
configure banner
disable cli scripting permanent
configure idletimeout 20
enable idletimeout
configure debug core-dumps internal-memory
# Module dosprotect configuration.
disable dos-protect
configure dos-protect interval 1
Press <SPACE> to continue or <Q> to quit:configure dos-protect type l3-protect alert-threshold 4000
configure dos-protect type l3-protect notify-threshold 3500
# Module eaps configuration.
configure eaps fast-convergence off
configure eaps config-warnings on
disable eaps
# Module edp configuration.
configure edp advertisement-interval 60 holddown-interval 180
enable edp ports 1
enable edp ports 2
enable edp ports 3
enable edp ports 4
enable edp ports 5
enable edp ports 6
enable edp ports 7
enable edp ports 8
enable edp ports 9
Press <SPACE> to continue or <Q> to quit:enable edp ports 10
enable edp ports 11
enable edp ports 12
enable edp ports 13
enable edp ports 14
enable edp ports 15
enable edp ports 16
enable edp ports 17
enable edp ports 18
enable edp ports 19
enable edp ports 20
enable edp ports 21
enable edp ports 22
enable edp ports 23
enable edp ports 24
enable edp ports 25
enable edp ports 26
# Module elrp configuration.
disable elrp-client
# Module ems configuration.
disable log debug-mode
configure log filter DefaultFilter add event All
enable log target memory-buffer
configure log target memory-buffer filter DefaultFilter severity Debug-Data
configure log target memory-buffer match Any
configure log target memory-buffer format timestamp hundredths date mm-dd-yyyy event-name condition severity
configure log target memory-buffer number-of-messages 1000
enable log target nvram
configure log target nvram filter DefaultFilter severity Warning
configure log target nvram match Any
configure log target nvram format timestamp hundredths date mm-dd-yyyy event-name condition severity
disable log target console
configure log target console filter DefaultFilter severity Info
configure log target console match Any
configure log target console format timestamp hundredths date mm-dd-yyyy event-name condition severity
# Module epm configuration.
configure sys-recovery-level All
Press <SPACE> to continue or <Q> to quit:enable watchdog
configure firmware install-on-demand
enable cpu-monitoring interval 20 threshold 90
# Module esrp configuration.
configure esrp mode extended
# Module etmon configuration.
configure sflow sample-rate 8192
configure sflow max-cpu-sample-limit 2000
configure sflow poll-interval 20
disable sflow
disable rmon
# Module hal configuration.
configure iproute sharing max-gateways 4
# Module lldp configuration.
configure lldp transmit-interval 30
configure lldp transmit-hold 4
configure lldp reinitialize-delay 2
configure lldp transmit-delay 2
configure lldp snmp-notification-interval 5
configure lldp med fast-start repeat-count 3
# Module netLogin configuration.
configure netlogin dot1x timers server-timeout 30 quiet-period 60 reauth-period 3600 supp-resp-timeout 30
configure netlogin dot1x eapol-transmit-version v1
enable netlogin logout-privilege
enable netlogin session-refresh 3
configure netlogin base-url "network-access.com"
configure netlogin redirect-page "http://www.extremenetworks.com"
configure netlogin banner ""
# Module netTools configuration.
configure sntp-client broadcast vr VR-Mgmt
configure sntp-client update-interval 64
disable sntp-client
# Module poe configuration.
# Module snmpMaster configuration.
configure snmpv3 engine-id 03:00:04:96:6c:fe:7d
configure snmpv3 add user admin authentication md5 hex fc:b7:0d:11:db:80:f8:10:3b:f3:9f:94:d8:f3:fc:d9 privacy hex fc:b7:0d:11:db:80:f8:10:3b:f3:9f:94:d8:f3:fc:d9
configure snmpv3 add user initial
configure snmpv3 add user initialmd5 authentication md5 hex bc:d5:41:b9:45:d5:5c:57:32:ca:f0:15:55:8f:03:b2
configure snmpv3 add user initialsha authentication sha hex e9:45:84:59:72:01:cc:23:ab:5b:2d:68:1d:d4:d1:84:4a:ca:4d:35
configure snmpv3 add user initialmd5Priv authentication md5 hex 8b:ab:34:1a:c9:84:97:8d:d9:e9:05:c4:b3:98:99:48 privacy hex 8b:ab:34:1a:c9:84:97:8d:d9:e9:05:c4:b3:98:99:48
configure snmpv3 add user initialshaPriv authentication sha hex c8:aa:e2:dc:e7:52:20:85:6b:05:6f:27:d8:b0:5e:f0:a0:0b:61:b4 privacy hex c8:aa:e2:dc:e7:52:20:85:6b:05:6f:27:d8:b0:5e:f0:a0:0b:61:b4
configure snmpv3 add group v1v2c_ro user v1v2c_ro sec-model snmpv1
configure snmpv3 add group v1v2c_rw user v1v2c_rw sec-model snmpv1
configure snmpv3 add group v1v2c_ro user v1v2c_ro sec-model snmpv2c
configure snmpv3 add group v1v2c_rw user v1v2c_rw sec-model snmpv2c
Press <SPACE> to continue or <Q> to quit:configure snmpv3 add group admin user admin sec-model usm
configure snmpv3 add group initial user initial sec-model usm
configure snmpv3 add group initial user initialmd5 sec-model usm
configure snmpv3 add group initial user initialsha sec-model usm
configure snmpv3 add group initial user initialmd5Priv sec-model usm
configure snmpv3 add group initial user initialshaPriv sec-model usm
configure snmpv3 add access admin sec-model usm sec-level priv read-view defaultAdminView write-view defaultAdminView notify-view defaultNotifyView
configure snmpv3 add access initial sec-model usm sec-level noauth read-view defaultUserView notify-view defaultNotifyView
configure snmpv3 add access initial sec-model usm sec-level authnopriv read-view defaultUserView write-view defaultUserView notify-view defaultNotifyView
configure snmpv3 add access v1v2c_ro sec-model snmpv1 sec-level noauth read-view defaultUserView notify-view defaultNotifyView
configure snmpv3 add access v1v2c_ro sec-model snmpv2c sec-level noauth read-view defaultUserView notify-view defaultNotifyView
configure snmpv3 add access v1v2c_rw sec-model snmpv1 sec-level noauth read-view defaultUserView write-view defaultUserView notify-view defaultNotifyView
configure snmpv3 add access v1v2c_rw sec-model snmpv2c sec-level noauth read-view defaultUserView write-view defaultUserView notify-view defaultNotifyView
configure snmpv3 add access v1v2cNotifyGroup sec-model snmpv1 sec-level noauth notify-view defaultNotifyView
configure snmpv3 add access v1v2cNotifyGroup sec-model snmpv2c sec-level noauth notify-view defaultNotifyView
configure snmpv3 add mib-view defaultUserView subtree 1 type included
configure snmpv3 add mib-view defaultUserView subtree 1.3.6.1.6.3.16 type excluded
configure snmpv3 add mib-view defaultUserView subtree 1.3.6.1.6.3.18 type excluded
configure snmpv3 add mib-view defaultUserView subtree 1.3.6.1.6.3.15.1.2.2.1.4 type excluded
configure snmpv3 add mib-view defaultUserView subtree 1.3.6.1.6.3.15.1.2.2.1.6 type excluded
configure snmpv3 add mib-view defaultUserView subtree 1.3.6.1.6.3.15.1.2.2.1.9 type excluded
configure snmpv3 add mib-view defaultAdminView subtree 1 type included
configure snmpv3 add mib-view defaultNotifyView subtree 1 type included
Press <SPACE> to continue or <Q> to quit:configure snmpv3 add community private name private user v1v2c_rw
configure snmpv3 add community public name public user v1v2c_ro
configure snmpv3 add notify defaultNotify tag defaultNotify
enable snmp access
enable snmp traps
# Module stp configuration.
configure mstp region 0004966cfe7d
configure mstp revision 3
configure mstp format 0
configure stpd s0 mode dot1d
configure stpd s0 forwarddelay 15
configure stpd s0 hellotime 2
configure stpd s0 maxage 20
configure stpd s0 priority 32768
disable stpd s0 rapid-root-failover
configure stpd s0 default-encapsulation dot1d
enable stpd s0 auto-bind vlan Default
configure stpd s0 tag 0
disable stpd s0
# Module telnetd configuration.
configure telnet vr all
# Module tftpd configuration.
# Module thttpd configuration.
enable web https
X350-24t.3 # sh port X350-24t.3 # sh ports info X350-24t.3 # sh ports information de X350-24t.3 # sh ports information detail
Port:1
Virtual-router:VR-Default
Type:UTP
Random Early drop:Unsupported
Admin state:Enabled with auto-speed sensing auto-duplex
Link State:Ready
Link Counter: Up 272 time(s)
VLAN cfg:
Name: gtf, Internal Tag = 1035, MAC-limit = No-limit, Virtual router: VR-Default
Name: voz, 802.1Q Tag = 210, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
Name: gtf Protocol: ANY Match all protocols.
Trunking:Load sharing is not enabled.
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Unicast Flooding:Enabled
Multicast Flooding:Enabled
Press <SPACE> to continue or <Q> to quit:Broadcast Flooding:Enabled
Jumbo:Disabled
Link up/down SNMP trap filter setting:Enabled
Egress Port Rate:No-limit
Broadcast Rate:No-limit
Multicast Rate:No-limit
Unknown Dest Mac Rate:No-limit
QoS Profile:None configured
Ingress Rate Shaping : Unsupported
Ingress IPTOS Examination: Disabled
Ingress 802.1p Examination: Enabled
Ingress 802.1p Inner Exam: Disabled
Egress IPTOS Replacement:Disabled
Egress 802.1p Replacement:Disabled
NetLogin: Disabled
NetLogin port mode: Port based VLANs
Smart redundancy: Enabled
Software redundant port: Disabled
auto-polarity: Enabled
Port:2
Type:UTP
Press <SPACE> to continue or <Q> to quit:Random Early drop:Unsupported
Link State:Active, 1Gbps, full-duplex
Link Counter: Up 1489 time(s)
VLAN cfg:
Name: grn, Internal Tag = 1064, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
Name: grn Protocol: ANY Match all protocols.
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Egress Port Rate:No-limit
NetLogin: Disabled
Port:3
Type:UTP
Link State:Active, 10Mbps, full-duplex
Press <SPACE> to continue or <Q> to quit:Link Counter: Up 2012 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Unknown Dest Mac Rate:No-limit
NetLogin: Disabled
Port:4
Type:UTP
Link State:Active, 100Mbps, full-duplex
Link Counter: Up 194 time(s)
Press <SPACE> to continue or <Q> to quit:VLAN cfg:
Name: DAF, Internal Tag = 1063, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
Name: DAF Protocol: ANY Match all protocols.
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Ingress IPTOS Examination: Disabled
NetLogin: Disabled
Port:5
Type:UTP
Link Counter: Up 7 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Egress IPTOS Replacement:Disabled
NetLogin: Disabled
Port:6
Type:UTP
Link Counter: Up 2460 time(s)
VLAN cfg:
STP cfg:
Press <SPACE> to continue or <Q> to quit:Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Press <SPACE> to continue or <Q> to quit:NetLogin port mode: Port based VLANs
Port:7
Type:UTP
Link Counter: Up 1200 time(s)
VLAN cfg:
STP cfg:
Protocol:
Press <SPACE> to continue or <Q> to quit:EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Press <SPACE> to continue or <Q> to quit:auto-polarity: Enabled
Port:8
Type:UTP
Link State:Ready
Link Counter: Up 507 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Press <SPACE> to continue or <Q> to quit:Unicast Flooding:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:9
Press <SPACE> to continue or <Q> to quit:Virtual-router:VR-Default
Type:UTP
Link Counter: Up 584 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Press <SPACE> to continue or <Q> to quit:Jumbo:Disabled
NetLogin: Disabled
Port:10
Type:UTP
Press <SPACE> to continue or <Q> to quit:Admin state:Enabled with auto-speed sensing auto-duplex
Link Counter: Up 2354 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Broadcast Rate:No-limit
NetLogin: Disabled
Port:11
Type:UTP
Link Counter: Up 785 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:QoS Profile:None configured
NetLogin: Disabled
Port:12
Type:UTP
Link Counter: Up 692 time(s)
VLAN cfg:
Press <SPACE> to continue or <Q> to quit: Name: grn, Internal Tag = 1064, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Ingress 802.1p Examination: Enabled
NetLogin: Disabled
Port:13
Type:UTP
Link Counter: Up 502 time(s)
VLAN cfg:
Press <SPACE> to continue or <Q> to quit:STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Egress 802.1p Replacement:Disabled
NetLogin: Disabled
Port:14
Type:UTP
Link Counter: Up 1139 time(s)
VLAN cfg:
STP cfg:
Protocol:
Press <SPACE> to continue or <Q> to quit: Name: grn Protocol: ANY Match all protocols.
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Press <SPACE> to continue or <Q> to quit:Smart redundancy: Enabled
Port:15
Type:UTP
Link Counter: Up 1398 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
Press <SPACE> to continue or <Q> to quit:ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:16
Type:UTP
Link Counter: Up 626 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Press <SPACE> to continue or <Q> to quit:Multicast Flooding:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:17
Press <SPACE> to continue or <Q> to quit:Type:UTP
Link Counter: Up 523 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Link up/down SNMP trap filter setting:Enabled
NetLogin: Disabled
Port:18
Type:UTP
Press <SPACE> to continue or <Q> to quit:Link State:Active, 1Gbps, full-duplex
Link Counter: Up 735 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Multicast Rate:No-limit
NetLogin: Disabled
Port:19
Type:UTP
Link Counter: Up 198 time(s)
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Ingress Rate Shaping : Unsupported
NetLogin: Disabled
Port:20
Type:UTP
Link State:Ready
Link Counter: Up 0 time(s)
VLAN cfg:
Press <SPACE> to continue or <Q> to quit: Name: voz, 802.1Q Tag = 210, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
Press <SPACE> to continue or <Q> to quit:Ingress 802.1p Inner Exam: Disabled
NetLogin: Disabled
Port:21
Type:UTP
Redundant Type:NONE
Link Counter: Up 137 time(s)
VLAN cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Preferred medium: Fiber
Port:22
Type:UTP
Redundant Type:NONE
Link Counter: Up 9 time(s)
VLAN cfg:
STP cfg:
Press <SPACE> to continue or <Q> to quit: Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:23
Type:UTP
Redundant Type:NONE
Link Counter: Up 1 time(s)
VLAN cfg:
Name: Default, 802.1Q Tag = 100, MAC-limit = No-limit, Virtual router: VR-Default
Name: mng, 802.1Q Tag = 120, MAC-limit = No-limit, Virtual router: VR-Default
Name: gtf, 802.1Q Tag = 1035, MAC-limit = No-limit, Virtual router: VR-Default
Name: GCEF, 802.1Q Tag = 1081, MAC-limit = No-limit, Virtual router: VR-Default
Name: USOC, 802.1Q Tag = 1009, MAC-limit = No-limit, Virtual router: VR-Default
Press <SPACE> to continue or <Q> to quit: Name: dse, 802.1Q Tag = 1033, MAC-limit = No-limit, Virtual router: VR-Default
Name: lgra, 802.1Q Tag = 1046, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:24
Type:UTP
Redundant Type:NONE
VLAN cfg:
Press <SPACE> to continue or <Q> to quit: Name: gtf, 802.1Q Tag = 1035, MAC-limit = No-limit, Virtual router: VR-Default
Name: grn, 802.1Q Tag = 1064, MAC-limit = No-limit, Virtual router: VR-Default
Name: DAF, 802.1Q Tag = 1063, MAC-limit = No-limit, Virtual router: VR-Default
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:25
Type:NONE
Admin state:Enabled with 10G full-duplex
Link State:Not present
VLAN cfg:
STP cfg:
Protocol:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
Port:26
Type:NONE
Link State: Not present
VLAN cfg:
STP cfg:
EDP:Enabled
ELSM:Disabled
Learning:Enabled
Jumbo:Disabled
NetLogin: Disabled
X350-24t.4 #
X350-24t.4 # log X350-24t.4 # logout
