yet another DHCP Snooping problem
scott.hammond
We have had a rash of problems with rogue DHCP servers of late so its time to bite the bullet and enable snooping. Problem is I cant get it to work.
With it enabled the test phone cant get an IP from the production DHCP server but rather it will only pull one from the "rogue" server that is untrusted.
I have tried every option, every variation, all vlans did nothing, turning off option 82 did nothing, tried using the database, nothing...I just never see bindings.
Please help!
I have a C3560CPD-8PT-S
ip dhcp snooping vlan 154
ip dhcp snooping
interface GigabitEthernet0/4 < Cisco phone
switchport access vlan 154
switchport mode access
spanning-tree portfast
ip dhcp snooping limit rate 100
interface GigabitEthernet0/8 < cisco 2811 playing the part of the rogue DHCP server
interface GigabitEthernet0/10 < uplink to the Windows DHCP
switchport trunk allowed vlan 1,43,154,200,1000
switchport mode trunk
ip dhcp snooping trust
interface Vlan1000 < The L3 management interface
ip address 10.60.250.115 255.255.255.0
comms_temp_s01#show ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
154
DHCP snooping is operational on following VLANs:
154
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
   circuit-id default format: vlan-mod-port
   remote-id: 5897.1ed1.2280 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
GigabitEthernet0/1         no         no              100
  Custom circuit-ids:
GigabitEthernet0/2         no         no              100
  Custom circuit-ids:
GigabitEthernet0/3         no         no              100
  Custom circuit-ids:
GigabitEthernet0/4         no         no              100
  Custom circuit-ids:
GigabitEthernet0/5         no         no              100
  Custom circuit-ids:
GigabitEthernet0/6         no         no              100
  Custom circuit-ids:
GigabitEthernet0/7         no         no              100
  Custom circuit-ids:
GigabitEthernet0/8         no         no              100
  Custom circuit-ids:
GigabitEthernet0/10        yes        yes             unlimited
  Custom circuit-ids:
comms_temp_s01#
15 Replies 15
scott.hammond
now the question is how do I mark this as answered when I answered my own question ........
