Zabbix gets strange data from nexus 5596UP
dijix1990
I have two nexus 5596UP are working in VPC and recently Zabbix starts to get strange data from one nexus 5596UP via snmp
There are no errors in the log
Maybe somebody know about it. I reboted it, but it didn't help
10 Replies 10
marce1000
 - Usually those traffic sparks are real but not  yet identified (which apps and or hosts causing it) , consider a netflow setup where then you can also analyze the traffic  (e.g.) ,
 M.
As I know the nexus 5596up can't use netflow. I use netflow with snmp on the cisco catalyst and on the every router.
Maybe I bumped into a bug, but I don't access https://quickview.cloudapps.cisco.com/quickview/bug/CSCuy23473
 - The bug is for CiscoPro Workgroup EtherSwitch Software , so unrelated ,
 M.
Does it have workaround?
this traffic can sync between two NSK SW.
NSK in vPC exchange Sync
It happens with every interfaces it doesn't matter onboard port or extra module or fex
dijix1990
I reloaded again and it helped
If happened again
Show interface
Check if unicast broadcast or multicast count increase rapidly
Yoh can have unknown unicast issue or broadcast strom in your case I dont think so but let us check.
I was watching. there was nothing special there. All nexuses work with snmp strangely . I mean, when I use a 1 minute interval to poll tx/rx traffic I see sawtooth graphs, independent of the polling system, zabbix/grafana/solarwinds. The survey works fine with an interval of 150 seconds
