Zones on an ASR 1001-X
johnsmunoz
I have an ASR that I'm using to connecting our ExpressRoutes and 10G links back to our headquarters. I'd like to add our DIA as well but I'm having a hard time finding out how to setup security on this device.  (ie, block SSH, SNMP, HTTPS from the DIA interface, etc)  Some reading indicates that I should be able to use ZONES on it but the commands are unrecognized on my unit.  Do I need an upgrade to be able to use ZONES?  Is there a different way I should be implementing security on this device?
EQX-DA2-ASR#show rom-monitor r0
System Bootstrap, Version 15.4(2r)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1994-2014  by cisco Systems, Inc.
EQX-DA2-ASR#show platform
Chassis type: ASR1001-X
Slot      Type                State                 Insert time (ago)
0         ASR1001-X           ok                    1d04h
 0/0      BUILT-IN-2T+6X1GE   ok                    1d04h
R0        ASR1001-X           ok, active            1d04h
F0        ASR1001-X           ok, active            1d04h
P0        ASR1001-X-PWR-AC    ok                    1d04h
P1        ASR1001-X-PWR-AC    ok                    1d04h
P2        ASR1001-X-FANTRAY   ok                    1d04h
Slot      CPLD Version        Firmware Version
0         14041015            15.4(2r)S
R0        14041015            15.4(2r)S
F0        14041015            15.4(2r)S
you need at least IOS XE Release 2.1 for the ZBF feature to be available...
That said, if all you want to do is block certain protocols from the interface, why not use an access list ?
