Zyxel prestige 600 series
ntleukin1985
This modem is connected to Computer that is connected to LAN. And if this computer is turned off, the internet on other computers
is disconnected. How can i connect this modem to provide an internet to other computers, even if the Server is off.
valentin.ene
You need an gateway device which can be a standalone router or an computer running special software. Depending what is your expectations about this device you may take a look at some soho routers from Linksys (the cheap solution and the simple one) or you may buy a more powerful device like Cisco routers. If you want to use a dedicated computer for this service I advice you to use a Linux SO specially designed for router service, like IPCop or SmoothWall
