12-21-2020 06:28 AM
Greetings,
Requesting stencils for Catalyst 8300 and 8500, or at least the location in case I missed it.
Solved! Go to Solution.
12-21-2020 06:54 AM
this is latest what cisco has : (until anything shared privately not aware of)
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
12-21-2020 06:54 AM
06-11-2021 07:39 AM
Can we get Cisco Catalyst 8200 Stencils? I'm not sure why there would be 8300 and 8500 but not 8200.
08-10-2023 04:56 AM
Is there any visio stencil that contains C-NIMs and C-SMs?
04-05-2023 08:30 AM
The 8200 is in the existing stencil, but I'm guessing it's not correct. 8300 is missing.
01-17-2024 07:31 AM
Esteemed, bumping this thread as we are in dire need of a stencil for the sixteen-port NIM module for the 8000 series routers.
Part number: C-SM-16P4M2X
06-26-2024 06:25 PM
Bumping as I also need the cisco 8300 series stencils which are currently missing as well as the C-SM-16P4M2X service module that can be installed into it
07-16-2024 08:53 AM
Same as LewJack1980_. I need the 8300 stencils as well. why after so long has this not been provided?
09-16-2024 03:12 PM
I see that there are Edge 8300/8500 stencils, and if they weren't in a format from 20 years ago (.vss) I might be able to open them and use them (blocked by security policy because the 20+ year format is less secure).
Can Cisco maybe release them in the newer .vssx or maybe both.
03-21-2025 12:56 PM
I ran into the same problem and used this free converter: https://products.groupdocs.app/conversion/vss-to-vssx
Seriously, it worked. 🤷
