1700MXP FIPS MODE ISSUE
Chet Cronin
Level 4
Level 4
Planning to enable FIPS mode on all my MXPs.
Tried it on my bench and now I am unable to browse using IE 11 on either HTTP or HTTPS when it's enabled ???
Any ideas ???
Chet Cronin
It's highly likely that you have TLS1.0 disabled in your browser.
  1. Go to Tools | Internet Options.
  2. Go to the Advanced tab.
  3. Scroll down to the Security settings.
  4. Make sure that the following check boxes are selected: Use SSL 2.0, Use SSL 3.0, and Use TLS 1.0.
  5. Click Apply.
  6. Click OK
Note: The 1700s reach their Last Date of Support on 28 February 2017, so I'd recommend that you consider replacing them with something more current.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne,
Thank you ... SSL 2.0 and 3.0 are not enabled on our browser.  TLS 1.0 is.
We don't control browser settings.  Will see what we can do to fix it.
Yes we are in the process of life cycle replacement project to upgrade all our systems to DX models.
VR
Chet
Chet Cronin
