1941 router & voip, iso/license
c005236861
I hope someone can enlighten me to my issue. I have a cisco 1941 router. and I am trying to see what I need to do an order for it to do VOIP.  another words what iso supports VOIP or is it just a license for VOIP.   I am not that knowledgeable when it comes to iso's and Licenses. Currently the image is c1900-universalk9-mz.SPA.154-3.M2.bin   . and when i do the show license I dont see anything about VOIP or UC.
Aman Soi
You do not have any iso on routers for Voice.I hope u are referring to SRST/CME which are RTU/Paper based licenses.
1941 does not support Voice .You can refer the link
https://supportforums.cisco.com/discussion/11341201/cisco-1941-router-support-voice
You can refer the link Table 3, Table 5 and Table 9for supported licenses on UC/Voice
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
regds,
aman
Aman Soi
regds,
aman
Thanks!
