2800 Voice calls dropping, local extensions also
fb_webuser
Level 6
Level 6
Cisco 2800 Router | I am having problem, calls are dropping frequently. ISP Side is fully tested, problem in router. calls are even dropping between localextensions
Posted by WebUser Amjad Ali
Aaron Harrison
If calls are dropping locally I would consider:
1) LAN Stability - check for excessive STP topology changes etc
2) Check the LAN interface of the router for errors
Are you running CUCM or CME?
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
fb_webuser
Level 6
Level 6
it is CME, same LAN Interface is working for internet there is no problem with it,
fb_webuser
Level 6
Level 6
problem was solved by, Frequency adjustment of Router with ISP
