04-20-2017 05:54 AM - edited 03-18-2019 01:01 PM
I am working on an SX80 with a Crestron control system. I am currently using the In Room control with the Touch 10 to control audio, video, lighting, and shades. What I need to be able to do now is know when a user has started the room from the panel so I can trigger whole room presets without having to tell the user to go into the In Room control and press another button. Is there a way to check for this with the API using a 3rd party control system?
Solved! Go to Solution.
04-20-2017 09:08 AM
You could use trigger the events in the room based on status feedback from the endpoint, for example: standby, call, sharing content, etc. Take a look at xStatus in the SX80 API Guides, and I suggest you take a look at the modules that are available from the Crestron Application Marketplace if you haven't already.
04-20-2017 09:08 AM
05-03-2017 06:18 AM
Patrick,
Thank you for that. That is what I was thinking just wanted to make sure I was on the right path. Implemented xStatus and I am now able to monitor when the unit is in standby.
