Showing results forĀ
Search instead forĀ
Did you mean:Ā
802.1X Bulk Configuration for SX20
Anas Hafez
I'm trying to enable  802.1X on SX20 endpoints registered to VCS and i didn't confirm yet if it will be using certificate or username and password but i wanted to know if there's a bulk method to apply that instead of manually configuring every single one of them, also this is going to be repeated in case of password change or certificate expiration, is there a way to do that?
Jonas Fraga
hello @Anas Hafez
If you register through CUCM you can use CAPF certificate as 802.1X validation which will allow all your devices to authenticate and authorize.
About other ways maybe API can be use to bulk cert install or use MAB method.
Thanks Jonas,
Please if you know, can you share some insight regarding the API option?
