CMS 3.2.1 - webbridge3
Paulo Ferreira
Level 4
Level 4
we ware trying to configure certificates in our cms in service webbridge3 and we are unable to start the service:
acano> pki verify webbridge3.cer BundleCARootWB3.cer
Success
acano> pki match webbridge3.key webbridge3.cer
Matching certificate and private key
acano> webbridge3 enable
FAILURE: HTTPS Key and certificate problem: certificate and key do not match
FAILURE: Webbridge3 configuration not complete
acano> webbridge3
Enabled : false
HTTPS listening ports and interfaces : a:443
HTTPS Key file : webbridge3.key
HTTPS Full chain certificate file : BundleCARootWB3.cer
HTTPS Frame-Ancestors : none
HTTP redirect : Enabled, Port:80
C2W listening ports and interfaces : a:999
C2W Key file : webbridge3.key
C2W Full chain certificate file : BundleCARootWB3.cer
C2W Trust bundle : BundleCARootWB3.cer
Beta options : none
our BuldleCARootWB3.cer was made following the documentation:
Entity cert
int cert
root cet
Any help?
we reinstalled the cms again and follow the same procedure with good results...
Matching certificate and private key>>
From your post, i don't see success for  your certificate match with the key.
Response Signature
Thanks for your repoly but the answer obtained from command pki match is the expected when is ok.
Best regards
Paulo Ferreira
