Analog Telephone Adapters (ATAs) |
ATAs connect non-IP devices, such as analog phones, fax machines, and overhead paging systems, to your network and allow them to act as Webex Calling devices. | ||
Cisco Webex Room, Board, and Desk Devices (Shared Mode only) | The following Room, Desk, and Board devices are fully supported on the Webex platform. They do not require a Webex Calling license unless PSTN calling is required. For PSTN calling, a Webex Calling Workspaces (formerly Places) license should be assigned to the device. PSTN for Personal Mode devices is not supported. For more information about these devices, go here. To activate your Room, Desk, or Board device on Cisco Webex, the device must run software version CE8.3.4 or later. You must use a TRC6 remote control with the SX20. The TRC5 is not supported. | ||
Conference Phones | The following conference phones support Multiplatform Firmware:
DECT Phones | Cisco IP DECT 6800 Series with Multiplatform Firmware
IP Phones (desk phones) | The following Cisco IP Phones support Webex Calling:
Your Cisco multiplatform device must run software version 11.0 or later (Cisco Webex Phone OS). To onboard your device using an activation code, firmware 11.2.3MSR1 is required. To check which phone model and platform you have, press Applications | ||
Phone Accessories | The following phone accessories support Cisco IP Phones with Multiplatform Firmware:
You can't use enterprise expansion modules with multiplatform devices. The multiplatform key expansion modules have different SKUs and aren't interchangeable. Use the following SKUs when you order an expansion module for a multiplatform phone:
