9 port personal bridge
Steve Coady
All
My understanding of TeleP bridges are
4 port Adhoc
9 port personal
12 port
As part of the package we purchased, we have the 9 port bridge. Can someone please advise on what steps to follow to allow
9 participants to have audio/video conference call when using eoither EX90 or MX300?
sMc
8 Replies 8
Steve Coady
anyone have experience with this topic?
sMc
Hi Steve,
I have read your topic many times, but I really didn't understand your doubt. Can you describe what you have purchased?
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
I was advisd to dial into My bridge, then each partcipant would dial into my directory name. That only allowed audio only.
For me to have a  video/audio conference call, with up to 9 participants, what steps need to be followed?
sMc
Hi Steve,
In order to have a conference with audio and video enabled, you need to have a bridge that supports audio and video, that is called MCU (Multipoint Control Unit). Cisco has many models of MCUs with different number of ports (the number of participants you can join) and different video quality (SD, HD, HD+, FullHD...).
Cisco Telepresence EX90 has a embedded MCU, It has support to host a multipoint conference with up to 4 participants with audio and video. If you need multipoint conferences with more partcipants, you should look for a dedicated Cisco MCU with the number of ports you need.
Cisco Telepresence MX series (MX200 e MX300) has no support for embedded multipoint resources.
Paulo Souza
Thank you for the response. I am checking on some contract details and will provide conclussion soon
sMc
You might have some mcu resources in your own infrastructure or for example at some cloud service provider.
The 4/9/12 definition is nothing techical and sounds more like some sales mapping ;-)
Like Paulo mentioned, the MX200 does not support local video multisite (btw the EX90 also
requires some additional license key for it). But as you have experianced it supports an
additional caller as audio.
But the EX90/MXx00 support multiway which is some escalation method to a mcu (service)
this would also match that you could select which size you wanted.
It can be that you have to set up your meetingroom address as the multiway address and then
use the join functionality.
But like you said, check what you ordered / got, also if its not you who is responsible for the system and
infrastructure and give us a feedback what you have and if you still have questions.
ALL
Thanks to both of you for your help.
I believe my issue is resolved. Finding the right Cisco documentation is half the battle!
Ther are so many, almost too many.
     Cisco TeleP Video systems
     Using the Cisco Webex TeleP brige Service
     Webex TeleP technical overview
     Cisco TeleP Systeme EX90/EX60 Admin guide
     EX90 user guide
     Cisc TeleP MX series
     Cisco Webex Telepresence - User's guide (last doc I found and this provided the steps)
The steps required to use a 9 port bridge are as follows.
     The host dials his/herown personal bridge ex. My Bridge: (display_name)
     Each partcipant must type in the hosts personal bridge, as opposed to selectig it from the Director because
     the required entry is reverse from what is noted in the directory.
To verify this I am setting up a compnay wide test
sMc
Hi Steve, thx for the feedback.
Maybe you should challange the partner which helps you with the keywords "multiway"
(endpoint based escalation to the MCU, rather than telling people to dial in to a meeting room
(which sure works also great!)).
Its always a mix of sales, technical stuff and not to forget routines around how to use.
I am not sure how big you want to scale, but telepresence server and conductor might also
be something to check out.
Good success with your test!
