07-18-2013 10:31 AM - edited 03-18-2019 01:28 AM
Hey,
I was reading through QoS guides and got confused about the threshold things.......
According to document,
you can use following command to configure maximum memory allocation for egress queue.
mls qos queue-set output qset-id threshold queue-id drop-threshold1 drop-threshold2 reserved-threshold maximum-threshold
you can use following command to configure allocated memory for egress queue.
mls qos queue-set output qset-id buffers allocation1 ... allocation4
So now questions:
1. Why queue-set? There will be 4 queue for egress anyway...
2. If queue-set is useful feature, Why no queue-set for ingress?
3. Why multiple thresholds? For ingress, there will be one threshold per queue.
4. When is drop-threshold1 used? When will drop-threshold2 used?
/S
07-23-2013 11:22 AM
So either everyone is confused as I am OR I confused everyone with my questions and no one bother to ask...
07-23-2013 01:30 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Or, perhaps this isn't the best forum for this question.
See if this document helps: https://supportforums.cisco.com/docs/DOC-8093
