08-19-2015 12:05 AM - edited 03-18-2019 04:52 AM
I have Tanberg Tanberg TTC8-01 camera. And i wanna connect it to my pc for using adobe virtual meeting. Is it possible? If it is possible, how can i do connection? could you help me?
Thank you for your support
08-19-2015 07:04 AM
It's not possible to use the PrecisionHD Cameras that come with the codecs as a computer web camera. I've seen one solution posted online a few years ago on another site, but I can't find it anymore, however it required several 3rd party components to make it work.
05-26-2018 08:11 PM
06-04-2018 10:31 PM
You could get the video in without much of a problem (all you'd need is a way to get the HDMI feed in to your PC - which you can get many different devices off the shelf to be able to do that). If you want the PTZ control of the camera, then that's going to be an issue.
Please remember to mark helpful responses and to set your question as answered if appropriate.
