04-21-2021 10:59 AM
You are trying to use xAPI (/v1/xapi/command/{commandName}) among webex teams apis.
When testing the API on the 'https://developer.webex.com/docs/api/v1/xapi/execute-command' site, the API works as expected.
When testing with postman, it is forwarded to'HTTP Status 403-Forbidden' as follows. do.
Other APIs are well used by using the same assigned AccessToken.
The scope is also spark:all and includes xAPI. Why not?
Solved! Go to Solution.
04-21-2021 11:18 AM
04-21-2021 11:18 AM
Advice you to head over to DevNet to ask questions about APIs.
04-07-2022 08:28 AM
You'll need to get the OAuth Token first.
