Accessing the Webex Codec Plus
jakinhays
Hi, there! I’m pretty new to the whole Cisco thing and I’m running into some issues. I was recently given a Cisco Webex Room Kit Plus by someone who no longer needed it and I’m trying to figure out how to log into the codec. I typed the IP into my browser and used “Admin” for the user name and I didn’t put anything for the password but that did not work. Any help at all would be much appreciated!
15 Replies 15
jakinhays
I'd like to note, I have factory reset the codec too.
Thanks for the reply!
I have attempted resetting it multiple times through different methods. I tried using the pinhole on the back by holding it for 10, 30, even 60 seconds, and I have tried resetting it from the touch panel as well but still cannot seem to get it to work. I have listed the process, in which I go through when I reset the device, in another comment.
Wayne DeNardi
Use "admin" as the username rather than "Admin" - it's case sensitive.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thanks for the reply, Wayne. I have tried “admin”, “Admin”, “Cisco”, and “cisco”. I have also tried
username: Admin
password: (blank)
username: admin
password: (blank)
username: admin
password: Cisco1234
username: Admin and admin
Password: Admin and admin
password: Password and password
I’m not sure what to try. Do I need to connect it to my Mac via USB or anything?
If you have completely factory reset the unit (and not done any configuration or cloud registration on the device), the default of "admin" with a blank password will work.
If the unit is registered to Webex, then you will need to access it via Webex Control Hub - or get your Webex Admin to create you a local userid/password combination to use to access it locally.
Wayne
TechLvr
Can you factory reset it again using the pin hole at the back of the device? Just hold it down for 10 seconds (obviously when the device is powered on).
Once it properly reset, use the same password combination again starting with username=admin and no password.
Here is the process I go through when I reset it if this helps at all.
boot -> connect to WiFi -> select Cisco WebEx option -> enter 16 digit pin generated on WebEx app -> set date and time -> calibrate camera -> calibrate microphone and speakers -> done
TechLvr
Ah Ok. Then you already registered it to the WebEx cloud.
WebEx registered devices are not initially accessible directly/localy via GUI by browsing to it's IP address.
You need to log into the device via the Control Hub (WebEx Cloud)
Once you log in to the device via the cloud, you can create a local user account on your device, that way you can log in both localy or via the control hub
Gotcha. So, I have tried to go to Admin.webex.com and when I try to login, it says “Unauthorized”. How do I become authorized to access the Control hub? Do I need a subscription in order to use the control hub?
Sorry, I’m a super noob with this stuff.
Who provided the 16 digit registration code to enter on your device?
They should be able to help you create a local user account for you
If you are not an admin user, you cannot log into admin.webex.com
I simply logged into the webex app on iOS -> settings -> devices -> generate activation code.
Next time you do a factory reset, do not go through the whole set up process (do not enter the 16 digit code).
As soon as you connect the device to WiFi and it obtains and IP address, stop right there with the device configuration. Then web browse to the IP address of the device and login using the credentials you tried before.
TechLvr
Here I just found the document to help you create a local user account.
https://help.webex.com/en-us/article/jkhs20/Local-User-Administration-on-Room-and-Desk-Devices
