ad-hoc conference call using telepresence conductor.
dijin1986
Dear Friends,
   I have implemented a telepresence system with CUCM10.5, Telepresence server (version 4.1) and telepresnce conductor (Version XC3.0.3)(both are installed in VM).  I have 4 MX300 codecs. the issue is, i am making an ad-hoc conference call and when i add the third party in the call by using the "merge" key, then the  video call become audio call only. Please help me to solve this issue
I used below CVD document for reference ,
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Collaboration/Feb2014/CVD-VideoConferencingUsingBE6000-Feb14.pdf
Dijin
dijin1986
please find the below logs,
2015-09-02T15:27:15+04:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:27:15,647"
2015-09-02T11:27:14+00:00 request-ntp-keygen[23638]: Event="ntp-keygen Requested" Level="INFO" UTCTime="2015/09/02-11:27:14"
2015-09-02T11:27:14+00:00 management: Level="INFO" Detail="Updating configuration file" Filename="/tandberg/persistent/ntp/crypto/pw" UTCTime="2015-09-02 11:27:14,452"
2015-09-02T11:27:14+00:00 management: Level="INFO" Detail="Updating ntpd configuration file" Filename="/tandberg/persistent/ntp.conf" UTCTime="2015-09-02 11:27:14,451"
2015-09-02T11:27:14+00:00 management: Level="INFO" Detail="Updating ntpd configuration file" Filename="/tandberg/persistent/ntp.keys" UTCTime="2015-09-02 11:27:14,447"
2015-09-02T11:27:14+00:00 management: Level="INFO" Detail="Updating configuration file" Filename="/tandberg/persistent/ntp/crypto/pw" UTCTime="2015-09-02 11:27:14,439"
2015-09-02T11:27:14+00:00 management: Level="INFO" Detail="Updating ntpd configuration file" Filename="/tandberg/persistent/ntp.conf" UTCTime="2015-09-02 11:27:14,438"
2015-09-02T11:27:14+00:00 management: Level="INFO" Detail="Updating ntpd configuration file" Filename="/tandberg/persistent/ntp.keys" UTCTime="2015-09-02 11:27:14,434"
2015-09-02T11:26:14+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:26:14,819"
2015-09-02T11:25:14+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:25:14,251"
2015-09-02T11:24:13+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:24:13,22"
2015-09-02T11:23:12+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:23:12,634"
2015-09-02T11:22:45+00:00 syslog-ng[10934]: Configuration reload request received, reloading configuration;
2015-09-02T11:22:23+00:00 conferencefactory.switchboard: Level="WARNING" Event="An API request could not be processed." Command="conference.create" Conference_name="0010350100050x357ae8a1ea6cc761" Detail="<Fault 201: '{"status":"error","info":"Not providing service"}'>" Xmlrpc_parameters="{'authenticationPassword': u'hidden', 'reservedVideoPorts': 3, 'enforceMaximumVideoPorts': False, 'durationSeconds': 3600, 'conferenceName': '001035010005', 'factory_request_ip': '10.18.10.40', 'cleanupTimeout': 60, 'factory_source_ip': '10.18.10.37', 'ownerID': {'deviceName': 'SEPE4C72263DBD1', 'devicePKID': '1ef3c7c2-0b18-e3f5-440a-967d250e768b'}, 'numericId': '001035010005', 'authenticationUser': 'cucmadmin'}" UTCTime="2015-09-02 11:22:23,869"
2015-09-02T11:22:23+00:00 conferencefactory.controller: Level="ERROR" Event="Incoming call request rejected." Reason="not providing service" Requester_(VCS/Unified_CM/client)_address="127.0.0.1" UTCTime="2015-09-02 11:22:23,867"
2015-09-02T11:22:23+00:00 conferencefactory.controller: Level="ERROR" Event="Request rejected. The TelePresence Conductor service is currently unavailable." Requester_(VCS/Unified_CM/client)_address="127.0.0.1" Status_good="False" UTCTime="2015-09-02 11:22:23,867"
2015-09-02T11:22:23+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="conference.create" Conference_name="001035010005" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:22:23,843"
2015-09-02T11:22:11+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:22:11,313"
2015-09-02T11:21:10+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:21:10,192"
2015-09-02T11:21:06+00:00 conferencefactory.switchboard: Level="WARNING" Event="An API request could not be processed." Command="conference.create" Conference_name="0010350100040x357ae8a1ea6cc761" Detail="<Fault 201: '{"status":"error","info":"Not providing service"}'>" Xmlrpc_parameters="{'authenticationPassword': u'hidden', 'reservedVideoPorts': 3, 'enforceMaximumVideoPorts': False, 'durationSeconds': 3600, 'conferenceName': '001035010004', 'factory_request_ip': '10.18.10.40', 'cleanupTimeout': 60, 'factory_source_ip': '10.18.10.37', 'ownerID': {'deviceName': 'SEPE4C72263DF3D', 'devicePKID': '95a2f4b7-8447-52c9-65f9-73c6d3469311'}, 'numericId': '001035010004', 'authenticationUser': 'cucmadmin'}" UTCTime="2015-09-02 11:21:06,974"
2015-09-02T11:21:06+00:00 conferencefactory.controller: Level="ERROR" Event="Incoming call request rejected." Reason="not providing service" Requester_(VCS/Unified_CM/client)_address="127.0.0.1" UTCTime="2015-09-02 11:21:06,972"
2015-09-02T11:21:06+00:00 conferencefactory.controller: Level="ERROR" Event="Request rejected. The TelePresence Conductor service is currently unavailable." Requester_(VCS/Unified_CM/client)_address="127.0.0.1" Status_good="False" UTCTime="2015-09-02 11:21:06,972"
2015-09-02T11:21:06+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="conference.create" Conference_name="001035010004" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:21:06,957"
2015-09-02T11:20:40+00:00 syslog-ng[10934]: Configuration reload request received, reloading configuration;
2015-09-02T11:20:08+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:20:08,371"
2015-09-02T11:19:08+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:19:08,218"
2015-09-02T11:18:06+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:18:06,740"
2015-09-02T11:17:06+00:00 conferencefactory.switchboard: Level="INFO" Event="A management request has been received." Command="device.query" Requester_(VCS/Unified_CM/client)_address="10.18.10.37" UTCTime="2015-09-02 11:17:06,376"
2015-09-02T11:16:11+00:00 conferencefactory.switchboard: Level="WARNING" Event="An API request could not be processed." Command="conference.create" Conference_name="0010350100030x357ae8a1ea6cc761" Detail="<Fault 201: '{"status":"error","info":"Not providing service"}'>" Xmlrpc_parameters="{'authenticationPassword': u'hidden', 'reservedVideoPorts': 3, 'enforceMaximumVideoPorts': False, 'durationSeconds': 3600, 'conferenceName': '001035010003', 'factory_request_ip': '10.18.10.40', 'cleanupTimeout': 60, 'factory_source_ip': '10.18.10.37', 'ownerID': {'deviceName': 'SEPE4C72263DF0F', 'devicePKID': '1d450904-02b4-61ff-7aba-acf63903a024'}, 'numericId': '001035010003', 'authenticationUser': 'cucmadmin'}" UTCTime="2015-09-02 11:16:11,123"
2015-09-02T11:16:11+00:00 conferencefactory.controller: Level="ERROR" Event="Incoming call request rejected." Reason="not providing service" Requester_(VCS/Unified_CM/client)_address="127.0.0.1" UTCTime="2015-09-02 11:16:11,121"
thanks,
Dijin
Hi Dijin,
I can see the following:
Are there any active alarms/warning popups in the top right hand corner?  If so can you post those alarms/warnings.
-Jonathan
Hi Jonathan,
  Yesterday i did some changes in the locations configurations and the ad hoc calls started working properly .I added 6 parties in the call and when i add the 7th call, the video became audio . But i found some alarms in the conductor and i am attaching here with this.
In the sales order we have  a Cisco TelePresence Server Resource License(LIC-300-PMP-1SL ), which i failed to update because of "invalid key error"  getting while installing the license and TAC case is going on. Is this alarm because of this license problem?
Please advise.
Dijin
