01-28-2013 12:29 PM - edited 03-18-2019 12:30 AM
I have a problem with the iPad login about with AD Authentication with the VCS. We have a Multi Domain forest. We can login with the Movi without Problems. We can login with the Jabber iPad without Problem.
But if we create a special Group with a Global Group with a special Domain, we must login with the movi as user: domain\user and password and the registration works fine. But if we try it with the iPad as user with domain\user and Password, the ipad could not register. I thin the Jabber for ipad have a problem with the string domain\user and Password. Could that the Problem with the Jabber Client Software or BUG? If I change my AD Group like local without the domain\ , the login on the iPad works fine, but I need for the Global AD the domain\.
THX
Please need a Feedback
Solved! Go to Solution.
01-28-2013 01:08 PM
HI. Sounds like you may be hitting -
The fix is going into 9.3 and hoping its targeting release sometime in April. Hope this helps.
VR
Patrick
01-28-2013 01:08 PM
VR
Patrick
01-28-2013 01:41 PM
Hi Patrick,
i hope
THX for your reply
