ADD TRAVERSAL CALL LICENSE TO EXISTING VIRTUAL VC EXPRESSWAY
cgarcial
Level 4
Level 4
Hi, hope someone can help! I need to add more traversal calls license to existing Virtual VCS expressway, (R-VMVCS-EXPWY-K9) which only came with 20 traversal calls and now need another 20, i can't find a spare number for this license and part number LIC-VCSE-20 VCS- 20 traversal calls is not a direct option on ccw. I can't find a top number for expansion on adding more traversal calls, does someone has any information on how to do this? thanks in advance.
Best regards...Charly
The GPL Part Number is L-VCS-PAK.  Then from within the PAK you can select L-VCSE-20.
Cheers!
Cheers!
thanks  a lot for your answer! appreciate it!!! have a great day!
