Adding User Through TMS Template
philokoi0
We have to add the same user/password on our 275 endpoints(SX, CX and MX running TC7.1.4), I want to know if it's possible using the TMS template?
Using the custom command we can change the adminpassword or menupassword but is it possible to add a user/password using this string?
Best regards,
Philippe
7 Replies 7
Patrick Sparkman
There is no API command to add users to the endpoints, this will have to be done through the web interface.
Thank you Patrick, no good news for us 😉
Philippe
No API command but it's possible to mimic what the web interface does in a script. Let me know if you're interested going this way and I'll be able to assist
Hi, of course I am interested, otherwise it could take a lot of time to create those acccounts on a lot of systems.
Adding a user via TMS Template - How to do? Thanks!
As mentioned earlier, it's only possible to add a user account to the endpoint by logging into the endpoint's web interface and adding it manually.
What is the script needed and does it work on CE version 8+
