API for 3rd party control of Touch10/SX80 based rooms
bhussey01
Please can someone direct me to the Touch 10 API, specifically the features that can be added to Touch 10 to customize a room, available from the SX80 webpage.
(I have the CE8.2.x API reference for integrators, so don't need basic API serial commands.)
Patrick Sparkman
There is no guides for the Touch 10, regarding the API that is.  I assume you're referring to the in-room control features, in which case you should take a look at the MX and SX Series In-Room Control Guide (CE8.2).
Patrick Sparkman
Thanks, that is what I was looking for.
One question came up as I delved into the programming: How are "Spinner" buttons and text windows done on the Touch10 editor?  It doesn't seem to be in the General menu of graphic elements, but maybe you have to combine certain elements.
Refer to the bottom of page 18 in the guide, you'll use the SetValue command to add or update text fields.  To see an example of the command in reference to the Spinner widget, refer to the bottom of page 23.
