AS5350 restriciting T1 PRI timeslots
khanuh
I have an AS5350 with 1 T1 PRI, is it possible to have 2 voice ports created allowing a different number of PRI time-slots in each, rather then all 24 channels bundled in one voice port. I know I can do this with channel-group but I want to achieve this with pri-group timeslot command.
venkekri
No you can not get two voice port from on T1 PRI.As all the B channels is governed by on Signalling D-channel, its not possible to create to D-channels from one T1 PRI.
venkekri
Giving it a bit more thought I realized the D channel problem, I will use the max-conn command to meet atleast a part of my requirements.
