ASP event log error 1309
ken.tucker
All,
I have TMS 14.1.1. My event log is full of events like the following. I don't know if it is ultimately causing issues but it sure is clogging up the event log.
Is this normal for anyone else? Thanks!
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 4/9/2013 3:12:57 PM
Event time (UTC): 4/9/2013 8:12:57 PM
Event ID: 7969e25f393743ca852a86585cc78218
Event sequence: 4533
Event occurrence: 1492
Event detail code: 0
Application information:
    Application domain: /LM/W3SVC/1/ROOT-1-130099664007404484
    Trust level: Full
    Application Virtual Path: /
    Application Path: C:\inetpub\wwwroot\
    Machine name: TMS
Process information:
    Process ID: 4460
    Process name: w3wp.exe
    Account name: IIS APPPOOL\DefaultAppPool
Exception information:
    Exception type: HttpException
    Exception message: A potentially dangerous Request.Path value was detected from the client (:).
   at System.Web.HttpRequest.ValidateInputIfRequiredByConfig()
   at System.Web.HttpApplication.PipelineStepManager.ValidateHelper(HttpContext context)
Request information:
    Request URL: http://tms.domain.com/http:/tms.domain.com/tms/public/external/phonebook/phonebookservice.asmx
    Request path: /http:/tms.domain.com/tms/public/external/phonebook/phonebookservice.asmx
    User host address: 187.102.162.xxx
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: IIS APPPOOL\DefaultAppPool
Thread information:
    Thread ID: 10
    Is impersonating: False
    Stack trace:    at System.Web.HttpRequest.ValidateInputIfRequiredByConfig()
Custom event details:
ken.tucker
Found out this error was due to an incorrect URL set on the endpoint. The URL for provisioning was set to the phone book URL!
12 Replies 12
mahkrish
Level 3
Level 3
Hi Ken, Let us know the windows operating system and servicepack details that host the TMS application. Also let us know the IIS version used.
BR, Mahesh Adithiyha
Mahesh,
It is Windows 2008 R2 64 bit with SP1 and all patches. IIS7.
I recently upgraded from 13.x to 14.1.1.  I don't know if these errors occured in v13 or not, unfortunately.
Thanks!
Ken
mahkrish
Level 3
Level 3
Hi Ken, After the upgrade to 14.1.1 was there any additional changes/configuration enabled on TMS. Is there TMSPE enabled for provisioning with VCS-Control ?
The only change made post-upgrade was setting "Route Phone Book Entries" to no. This was due to phonebook entries not being sent to endpoints behind a firewall (issue exists in v13 and v14 for me). Cisco TAC is still working up the problem in their lab (as I shouldn't have had to change this).
TMSPE was installed/enabled in v13 (used for Jabber Video) and still is.
Thanks!
Ken
Magnus Ohm
If this started to happen after you upgraded to TMS 14.1.1. The errors might be related to a bug in the tmssnmpservice. It crashes quite ofte . You can check this in the event logs of windows. Its related to .NET.
It should be fixed in the upcoming tms version. There are other threads in this forum discussing the same topic with error details that you can compare.
/Magnus
I definitely have the snmp service issue too, but since the event log seems to point to the phone book URL, it looked different to me. I'm not having any obvious problems now though so maybe it's not a big deal. Will see if 14.1.2/14.2 fix it.
Thanks!
Ken
Hi Ken, thank you for sharing the update. Since there is already TAC SR opened you may want to wait for their findings.
The TAC case was for another issue, I was just suggesting maybe it's related. I haven't mentioned this event log issue to the engineer.
Guess I'll see if 14.2/14.1.2 fixes it.
Thanks, all.
Ken
Hi Ken, IMHO, it's worth mentioning this problem to the existing TAC SR engineer to further analyze this problem.
ken.tucker
Hi Ken,
FYI. TMS 14.2 was released last week. Please refer to the below mentioned software download, release notes URL’s
  • Cisco TelePresence Management Suite 14.2
Software location: http://software.cisco.com/download/release.html?i=!y&mdfid=283613664&softwareid=280886992&release=14.2&os=
Release notes: http://www.cisco.com/en/US/docs/telepresence/infrastructure/tms/release_note/Cisco_TMS_Release_Note_14-2.pdf
Sumeet Rakesh
You can select the endpoint and do Enforce Managment settings and this should set the correct URL's on the endpoint.
Also, regarding the upgrade to 14.2 I would request you to wait for some more time due to some ongoing issues during the upgrade process.
Sumeet Rakesh
