06-21-2005 07:06 AM - edited 03-17-2019 08:28 PM
Hi All..
Can I use ATA 186 or 188 to connect with many others ATA or router with FXS VOIP without gatekeeper ?
Cassio Gomes
06-27-2005 09:02 AM
Yes , u can connect ATA 186 or 188 with many others ATA or router with FXS VOIP without gatekeeper
06-27-2005 12:34 PM
How ?
Cassio gomes
07-13-2005 06:18 PM
pls be so kind to explain how you do it using many ATA with H.323 and without a H323 gatekeeper (does not matter whether opensource or not).
You may do it with SIP and a sip server but what about ATA 186 using H.323 - where do you store all the dial peers ??
07-07-2005 03:39 PM
hi Cassio.gomes
i can replay on ur question with yes if u mean by gatekeeper that which is on IOS ; because there r some gatekeeper software that can put on any pc like
gnuk "as i remember"
