B
avnetwork2
On the sx20 camera extension using 2 of the CAB-PHD4XS2-SPLI is the cat 5 a true cross over cable (wo, o, wg, b, wb, g, wb, b to wg, g, wo, b, wb, o, wb, b) or is it ONLY pin 3 and 6 flipped?
Patrick Sparkman
You're going to need to make a custom cable most likey, as the pins don't line up per a straight-through or corssover cable, refer to the pin-out of the RJ45 female end of the CAB-PHD4XS2-SPLIT in the PrecisionHD Camera User Guide on pg 20.
Wayne DeNardi
If you only use one of the CAB-PHD4X2S-SPLIT cables and the CAB-HDMI-PHD12XS cable (Option 1), you can use a straight through cable.
If you're using two of the CAB-PHD4X2S-SPLIT cables (Option 2), you need to use a custom pinout.
See https://supportforums.cisco.com/sites/default/files/legacy/3/2/2/15364223-Extending_PHD_4xS2_Camera.pdf for description and pictures of both options.
For either solution, you will need to power the camera separately with a PSU-CAM-V (or equivalent).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
avnetwork2
Thanks for the responses, i was able to get that pin out figured out and working.
Glad to hear that you got it working.
Please remember to rate responses and to mark your question as answered to assist others in finding the right answer if they have a similar problem in the future.
Wayne
Wayne
