BE6000S and Video
Greetings,
I am having some issues determining if the BE6000S and its application set will support station to station video with the 88xx series phones?  Basically the end user wants to be able to have video calls from one exec to another exec when they are in separate locations.  If the 6000S will not support this function, what licensing will be required on the 6000M to support this type of functionality?
Would appreciate anyone's input on this subject.
-michael
Deepak Rawat
You can use Cisco BE6KS and do video to video calling provided both the end points support video capabilities. For a simple video to video call, CM is good enough and you can install CM on BE6KS
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/data_sheet_c78-717454.html
Deepak
Deepak Rawat
Deepak
Greetings Deepak,
Thanks for the quick response on this question, I had a feeling this was the case but needed confirmation.
Cheers
-michael
