05-14-2012 06:51 AM - last edited on 03-25-2019 09:03 PM by ciscomoderator
I have a Dell Latitude 5420. I purchased a USB to Serial interface to communicate thru serial port with MXP devices. I need to FLASH the memory of one of my units. The standard procedure is to do a BREAK command during boot up and type command eee in order to flash the memory. Unfortunatly, all these new keyboards don't have the BREAK function key available. Any ideas on how I can get my issue resolved?
05-14-2012 01:40 PM
Hi Steve,
Look in Putty or TeraTerm menus, you should be able to send a BREAK command from there.
05-14-2012 01:57 PM
Hi Thomas,
I tried that and it doesn't work. The issue is that it is not only a BREAK command that needs to be sent, it's a CTRL + BREAK command. I've tried it with Hyper-Terminal, Putty, TeraTerm with the same result. Also tried different ways of typing it in (CTRL + B, ALT + B, etc.) with the same result. By looking on the web, the issue seems to be more related to the fact that Windows 7 doesn't support the BREAK key. Therefore, even if I try to simulate it with commands in Putty or Hyper-Terminal, I can't seem to be able to do the CTRL + BREAK. Can anybody try to simulate it with their laptop and confirm if they were able to get thru? I sure can't....
05-14-2012 05:15 PM
Steve,
I know this is not ideal, however we always suggest hooking up USB keyboards to laptops so you can have the break key.
Justin
05-15-2012 11:45 AM
Hi Jason,
Tried that already but I think it's Windows 7 that doesn't understand the BREAK key itself. I was given a work around from CISCO to at least be able to access system commands thru telnet once the unit is booted up. It doesn't help me with my issue when an MXP system is stuck in a reboot loop, but, it does allow me to select software image or switch the units from PAL to NTSC (Cisco sends all the MXP replacements as PAL) which is normally done thru the system commands you can access once you do the CTRL + BREAK.
05-18-2012 01:20 AM
Hi Steve,
It won't solve your original issue, but from F9.0.2 you can choose between PAL and NTSC standards directly from the web interface. The URL is: http://MXP_IP/setproductversion.ssi
05-15-2012 03:18 PM
Hello Steve!
I just tried it with Win7/64, Putty with a cheap PL2303 USB2Serial adapter on a lenovo thinkpad
towards an MXP3000 running F9.1.1 and it worked with the integrated keyboad or with the
on-screen windows keyboard.
First check that your com port and serial port speed are correct, in my case it was COM7 and 9600.
Then open putty and the on screen keyboard (just search for keyboard in the windows search, think
its somewhere in accessories or something like that).
Reboot the codec, you should now see "Break ?" on the screen (if not most likely your connection is not ok).
I simply held down my Ctrl key and then clicked on the ScrLk button on the On-Screen Keyboard.
The faster way on the thinkpad was to press the Fn key together with break, often these keys
can be activated by some 2nd-level key function, ...
By that I would also say Justins external USB Keyboard method shall work fine as well.
Other options:
* Use a different computer with a different OS or just download yourself a bootable linux cd/usb-stick
* I think I had seen some terminal programms supporting such control codes as on screen buttons as well
and so on, ...
Good success!
Steve: Please rate the message using the stars below and set the thread to answered if it is.
Add-on:
Tried it with the putty break function mentioned by Thomas/Paul and worked like a charm as well:
(so no additional ctrl is required). Are your really sure the endpoint / cable / serial adapter / settings / ... are ok?)
05-17-2012 07:53 AM
Also in putty you can click on the icon in the top left title bar and navigate to special command > break. This is how I always do it and I have never had any issues.
11-12-2013 01:03 PM
I had the same issue in Windows 7.
Got my old XP laptop and the CTRL + BREAK works!
Now to find the right command for switching memory bank
01-18-2019 12:40 PM
click CTRL+C
01-31-2019 07:25 PM
@Lightsoff wrote:
click CTRL+C
Unfortunatley, a lot of windows apps treat Ctrl+C as "Copy", not as a Break. Ctrl+C and Ctrl+Break are different keypresses, and things requring a Ctrl-Break will often not work with just a Ctrl-C - hence why things like putty and other terminal emulation programs have a special way to send a Ctrl-Break.
From Microsoft's web site (https://docs.microsoft.com/en-us/windows/console/ctrl-c-and-ctrl-break-signals) Ctrl+Break is always treated as a signal, but an application can change the default Ctrl+C behavior.
Please remember to mark helpful responses and to set your question as answered if appropriate.
01-07-2023 03:11 PM
Just connect a USB keyboard to your notebook. It´ll work.
