Bug CSCuy46138 sur TMS version 15.4.0
cyrille vautier
I have a TMS server in version 15.4.0 and I have the bug CSCuy46138, has anyone also found this BUG on version 15.4.0, on the Cisco site, there are only the Versions 15.0, 15.1 and 15.2.
Is there a defined version for the bug fix?
Patrick Sparkman
The bug details say it's still open and there are no known fixed releases yet, if you're running any version of TMS after those that are confirmed affected, you can still run into the bug.  However, there is a chance you might not, for example where fixing one bug fixes another.
