C-60 DVI output
rvswhitlock
I have a C-60 and I only get green digital noise out of the DVI output 2.
Do I need a option key to enable this output?
Amlesh Sengar
Hi Randy,
C60 had the DVI enabled by default.  There is no need of an option key.
I believe you have already checked the cable used.
Amlesh
