C series codec software reload
david.sharp
I have noticed with the C series codec that Cisco provide that recently there appears to be problems with the firmware image becoming corrupted which is causing several problems.
we have a specific codec that has entered this state now, a C20, the codec is unstable to a point where we do not have enough time in the actual application itself to perform a firmware upgrade in an attempt to load a fresh copy of the firmware onto the unit. the system crashes and reboots.
we have been able to boot into the u-boot menu which I believe we should be able to gain access to the root interface, or the tshell.
I am also aware that it is possible to perform a firmware reload using a TFTP server in order to reload the firmware.
my question is, can I have the instructions on how to perform this firmware reload sent across please.
the specific problem I have is that I have a codec which is not under a support contract at the moment, so an RMA is not possible and the firmware appears to have become corrupt on the unit, if we are able to boot into the u-boot prompt or the root interface the codec appears stable, so I ideally would like to attempt a completely fresh application firmware recovery.
Cheers
Dave
Think with Portals
Think with Portals
Tomonori Taniguchi
