04-24-2015 12:31 AM - edited 03-18-2019 04:23 AM
Any one aware of why the C60 would go into maintenance mode after software upgrade from TC5.0.1 to TC7.2.1???
Software loaded and appears to install properly ???
Thanks.
04-24-2015 03:33 AM
Hi Chet,
You can try a factory reset in addition to the suggestions in the following post for similar issue
https://supportforums.cisco.com/discussion/12394476/c60-possibly-faulty
Manish
04-24-2015 03:35 AM
Hi Chet,
Manish
