C60 failed to display the presentation on the first screen.
Arbenjamin
Dear all,
Our client has report a abnomral behavior from C60 with TC5.1.5.
The device is connected to two output projector. The error message " Unsupported signal - The connected source (PC ) can't be displayed" is appeared on the first display while PC presentation works fine on the second display. Based on presentation page, we noted the received resolution is 1280X1024@ 60 Hz that is supported input signal.
I have checked the release note and search bug, there is no any report on this issue.
Anyone faces the same issue?
Best Regards,
Ben Lai
0 Replies 0
