C60 OUT OF THE BOX QUESTION
Chet Cronin
Level 4
Level 4
Does anyone know if the same firmware is installed in both sw1 and sw2 on a C60 out of the box???
SECOND QUESTION: What if any is the process to factory reset a C series codec if for some reason unable to use the serial port????
Thank You.
Chet Cronin
Magnus Ohm
Only one of the memory banks should be populated with a software version out of the box.
The second question depends on which C-series codec you mean. C20 can be hard factory reset (power button sequence) while C40, C60 and C90 cannot and must be done either through serial, web, touch, telnet or ssh where all of them except serial requires a network connection.
/Magnus
Magnus Ohm
/Magnus
That is what I thought.
Thank you.
Chet Cronin
