C90 HD-SDI min resolution
philokoi0
We have 4 C90 running TC5.1.5 and wanted to use our streaming cameras(lot of rooms switched through an SDI matrix) connected on the HD-SDI port.
We want to send SD-SDI(Anamorphic 16:9 into 4:3 625L 25Fps European Format) SMPTE 259M(270Mbit/s) video on the HD-SDI C90's Input, in the spec, they mentioned a min of 720P 25Hz but in the Cisco C90 Physical Interface Guide document, the support of SMPTE 259M ( 270Mbit/s) is mentioned.
We don't have any video on this entry in this configuration.
Is there a special configuration to support this format or is it not supported?
Thank you for your help,
Philippe
The C90 Data Sheet and Physical Interface Guide both list the following as the supported formats on the four HD-SDI Inputs:
  • 1920 x 1080@30 Hz (1080p30)
  • 1920 x 1080@25 Hz (1080p25)
  • 1280 x 720@60 Hz (720p60)
  • 1280 x 720@50 Hz (720p50)
  • 1280 x 720@30 Hz (720p30)
  • 1280 x 720@25 Hz (720p25)
I can see that it does mention SMPTE 259M in the Levels section, but only the above are listed as supported formats.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
