C90 with two Speakertrack 60 possible?
mpirron001
Is it possible to use two Speakertrack 60 units at the same time with one C90 in such a way, that the tracking functionality of both Speakertracks work?
If not, what would I have to do in order to get those two Speakertrack units to work at the same time?
Thanks!
Patrick Sparkman
It's only possible to use one SpeakerTrack with an endpoint, there is nothing you can do to make it work as it's not designed to work with more than one.
I feared as much - thank you for your fast reply!
