03-10-2008 10:53 AM - edited 03-17-2019 09:18 PM
Hi there,
We have the problem that we want to forward incoming external calls to a cell phone at sometime. However this does not work at the moment. When chosen call forward all to an external number and one rings the internal extension. This works fine. When somebody dials the DID number one hears ringing but no call is forwarded to the external destination.
Included you will find the script. Furthermore the debug of the successfull call transfer all when dialing the internal number and the debug of the non successfull call transfer all when the DID number is called.
Solved! Go to Solution.
03-11-2008 06:52 AM
Hi there,
When we put in this rule at the voice port or at the DP then the to be forwarded call is directly disconnected. So no normal call clearing then.
03-11-2008 07:24 AM
Send the trace again. Also send the trace when forward is successful from an internal phone.
Make sure there is a connect and you can talki for the latter, because the first trace you sent, did not showed connect.
03-11-2008 08:54 AM
03-11-2008 09:07 AM
Hi, the forward from external is still palced isdn/national:
Mar 11 15:50:20.355: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x4F
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x82
Preferred, B2
Called Party Number i = 0xA1, '00611395292'
Plan:ISDN, Type:National
Sending Complete
How did you configured the voice translation-rule ? You need to tie it to a voice translation-profile that in turne is applied as outgoing at voice-port or DP level.
03-11-2008 09:24 AM
Hi there,
Look below for the configuration of the DP:
voice translation-rule 4
rule 1 // // type any unknown plan any unknown
voice translation-profile doorschakel
translate calling 4
voice-port 0/1/0
compand-type a-law
cptone NL
I tried to put here at the voice port the rule translation-profile outgoing doorschakel but then the external caller recieves no ring tone at all.
Furthermore i put it in the DP below:
dial-peer voice 10 pots
description Uitgaand lokaal
destination-pattern 0[1-9]T
port 0/1/0
forward-digits all
When i put the outgoing translation-profile here then i do not get a ring tone when calling from external.
Maybe a problem with the BRI configuration ?
Look below:
interface BRI0/1/0
description Nummer 043-3270323
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn map address type plan unknown type unknown
isdn sending-complete
no isdn outgoing ie progress-indicator
no isdn outgoing ie caller-number
isdn static-tei 0
Thanks in advance for your reply.
03-11-2008 09:36 AM
Hi, should be:
translate called 4
the reason the "isdn map address" under bri0/1/0 is not working is because it should be like:
isdn map address . plan unknown type unknown
this command has the same effect like the translation-rule, so after it's fixed, you don't need both.
In fact "isdn map address" is simpler.
03-11-2008 10:17 AM
Hi there,
Thank you very very much. After applying the rule you mentioned everything is working fine now.
Your help is greatly appreciated.
03-11-2008 10:34 AM
Oh, that one took some time. Thanks for the nice rating and good luck!
