02-24-2021 08:13 AM - edited 02-24-2021 08:15 AM
In the Mobile and Remote Access Through Cisco Expressway Deployment Guide (X12.5) > Supported Deployments
Currently, ICE passthrough support exists only on MRA deployments. It is not tested and supported on the following service deployments:
Cisco Webex Hybrid Services
Jabber Guest
Microsoft Gateway
Collaboration Meeting Room (CMR) Cloud
Business to Business Calling
So does that mean i should have a dedicated expressway for MRA to have ICE enabled on it or it does mean it's not supported to enable ICE on B2B zone for example?
Solved! Go to Solution.
02-24-2021 06:48 PM
ICE feature is applicable to MRA registered endpoints, and no documents says that you need a separate expressway E-C pair to have MRA ICE feature. AFAIK you can have MRA with ICE and B2B on same expressway.
https://www.cisco.com/c/en/us/td/docs/solutions/PA/ICE/icepa125.html#pgfId-109825
02-24-2021 06:48 PM
