can i get a snapshot from a C40 via SSH ?
Thijs Van Severen
Is it possible to get a snapshot from a C40 system using SSH or wget ?
we are making some major changes in our lab and I have a C40 system that i want to set up in our Lab to film the progress of the renovations
the idea is to grab 1 frame every 20sec or so and use these to create a timelapse video of the renovations
with other cameras (IPcams and USB cams) i was able to do this with some very simple scripts using wget or some other basic tools, and i would like to do the same with the C40 since it has superior video quality
is there is a simple way to get a frame from the C40 ?
if there is a direct url for the snapshot image i could use wget to get it, or ...
all tips are welcome!
grtz
Thijs
Thijs Van Severen
just enabled root login and found 2 interesting files :
/tmp/snapshots/snapshot-1.jpg
/tmp/snapshots/snapshot-3.jpg
however ...
the resolution is 512x288 pixels, and i dont know how to trigger the snapshots via SSH
looking at the /dev dir i cant really see any video device ...
any tips ?
grtz
Thijs
